Exclusive Lens Solutions for Embedded Cameras
Lenses with various mount types, built for RPi cameras and any embedded systems.
M12 Mount lens solutions
C Mount solutions
CS Mount lens solutions
Lens Selection Guide
If you need more Lens options, Arducam also provides you with a more comprehensive free Lens Selection tool, please click:
Arducam Lens Selection Guide
M12 Lens Series
  • Wide range of focal lengths and FoVs.
  • Compatible with any Pi/Jetson/Arduino camera featuring an M12 lens.
  • Selective lens kits for quick evaluation.
  • Low distortions series.
  • Selective bundles (lens + tripod + adapter) for HQ camera.
  • Optional IR filters.
M12 Mount lens modules
M12 Lens KIT LK005
SKULN001LN065LN002LN003LN011LN012LN013LN005LN055LN007
Model No:M2516ZH01M2512ZH03M2508ZH02M2506ZH04M2504ZH05SM25360H06SM27280M07SM27210H08M27195H15M25170H12
Optical Format1/2.5”1/2.5”1/2.5”1/2.5”1/2.5”1/2.5”1/2.7”1/2.7”1/2.7”1/2.5”
EFL(mm)16128643.62.82.11.951.7
BFL(mm)7.16.58.17.33.242.752.66.33.84.7
Construction6G+IR6G+IR6G+IR6G+IR2G2P+IR2G2P+IR2G2P+IR6G+IR6G+IR6G+IR
F/NO2.02.02.02.02.83.02.82.02.02.0
FOV (D/H/V) on 1/2.7‘’ Cam25/22/1231/27/1548/42/2564/57/3480/72/4590/82/52103/95/63136/130/101158/155/136180/180/180
FOV (D/H/V) on 1/2.8‘’ Cam23/20/1129/25/1445/40/2362/55/3378/70/4388/80/5098/90/59131/125/94154/150/129180/180/180
FOV (D/H/V) on 1/2.9‘’ Cam20/18/1026/23/1343/38/2260/53/3276/68/4286/78/4993/85/55127/120/89149/145/121180/180/180
IR filter650 IR filter650 IR filter650 IR filter650 IR filter650 IR filter650 IR filter650 IR filter650 IR filter650 IR filter650 IR filter
MOD0.3m0.3m0.3m0.3m0.3m0.2m0.3m0.3m0.2m0.2m
Size(mm)14 x 16.214 x 16.714 x 16.914 x 17.414 x 18.714 x 16.314 x 15.614 x 15.217.5 x 19.920 x 18.7
4K M12 Lens
CS Mount lens modules
C-Mount Lens Series
  • Compatible with any Pi/Jetson/Arduino camera featuring a C-Mount lens.
  • Wide focal length range. (2.8mm ~ 50mm)
  • Adjustable aperture options.
  • Optional zoom control.
C-Mount Lens
CS-Mount Lenses
  • Wide focal length range. (3.2mm ~ 50mm)
  • Selective lens bundle w/ ultra wide angle options.
C Mount lens modules
CS-Mount Lens KIT LK004
Model No:CS2325ZM01CS2316ZM02CS1812ZM03CS2308ZM05CS1806ZM06
Optical Format1/2.3”1/2.3”1/2.3”1/2.3”1/2.3”
EFL(mm)25mm16mm12mm8mm6mm
BFL(mm)8.03mm7.53mm7.53mm6.50mm8.03mm
F/NOF1.2F1.6F1.6F1.4F1.4
FOV (H) on 1/2.3” Cam14° (H)24° (H)30° (H)50° (H)65° (H)
Lens MountCS mountCS mountCS mountCS mountCS mount
Weight47g45g53g40g47g
MOD0.2m0.2m0.2m0.3m0.3m
Size(mm)Φ28×29mmΦ30×29mmΦ30×29mmΦ28×23mmΦ28×28.5mm
CS-Mount Lens
pivariety cameras
  • Customized focal lengths.
  • FoVs tailored to your application needs.
  • Custom form-factor lens design
  • Various optical filter options.
  • Customized C/CS/M12-mount lens adapters.
