Arducam 16MP Wide Angle USB Camera, 1/2.8″ CMOS IMX298 4K Video Webcam With Microphone
$ 69.99
  • Ultra HD: This small camera module adopts 16MP IMX298 sensor for sharp image and accurate color reproduction, still picture resolution: 4656 x 3496 Max.
  • Wide Angle: Mounted a High quality 105 degree wide view angle (horizontal) M12 lens with IR filter, provides a wilder Field of View.
  • Applications: This tiny 38mmx38mm camera board can be installed in most narrow position, highly recommended for a home video surveillance system, dashcam and other vision applications demand high resolution.
  • Note: There is a lens shading problem after changing the lens, so we don’t recommend changing the lens.
SKU: B0268 Categories: ,
Arducam High Resolution Camera Module B0268 is based on Sony 1/2.8” 16MP Sony IMX298 image sensor, mounted with a high quality 105 degree (H) M12 Lens, UVC compliant USB 2.0 cameras.
No longer be anxious about installing the driver! The native UVC drivers of Windows, Linux, and Mac shall be compatible with this camera so that it does not require extra drivers to be installed.
Applications:
  • Video conference
  • Home video surveillance system
  • Day&night low light vision security camera system
  • Dash camera
  • Monitoring 3D printer
  • Baby Camera
  • Robot and machine vision
Features & Specs
  • Sensor: 1/2.8” IMX298
  • Resolution: 16MP 4656H x 3496V
  • Data Format: MJPG/YUY2
  • Frame Rate:MJPG 10fps@4656×3490/3840×2160/2592×1944/2320×1744, 30fps@1920×1080/1600×1200/1280×720/800×600/640×480/320×240;YUY2 5fps@1600×1200/, 10fps@1280×720, 15fps@800×600, 20fps@640×480/320×240,
  • Field of View (FOV): H= 105°
  • Lens Mount: M12
  • IR Sensitivity: Integral IR filter, visible light only
  • Focusing Range: 3.3ft (1M) to infinity
  • Auto Controlled Features: Saturation, Contrast, Acutance, White balance, Exposure.
  • System Compatibility: Windows, Linux (Android compatibility: contact us for support)
Power
  • Power Supply: DC 5V
  • Working Current: MAX 200mA
Physical
  • Operating Temp.: -4°F~167°F (-20°C~+75°C)
  • Dimension: 38mmx38mm
  • Cable Length: 3.3ft (1M)
  • 1 × 16MP IMX298 USB 2.0 camera board
  • 1 × 3.3ft (1M) USB 2.0 cable
Documentation:
user guide.pdf
windows usb camera module blog thumbnail
The Different Kinds of Camera Modules You Can Use with Windows PCs
Cameras on the Windows Platform If you click the start menu on Windows 10, you will probably find an app called “Camera.” On a laptop, the app shows the built-in front-facing camera with some simple controls, but how would you use a camera on the desktop end? Aside from a built-in webcam, there are several […]
Weight0.0315 kg
x86 PC
UVC USB Camera
USB 2.0
IMX298
16MP
High Resolution, Wide Angle
