As part of Project Jetvariety, which allows any camera modules to be connected to the high-speed CSI-2 connector on the Jetson Nano. Arducam released this 2MP Global shutter OV2311 camera module, and it can be connected directly to RPi’s CSI-2 camera interface without additional hardware. Based on 1/2.9-inch Omnivision OV2311 image sensor which adopts OmniPixel3-GS™ technology, it can provide full-frame, sub-sampled, and windowed 8/10-bit MIPI images, and capable of operating at up to 60fps in full resolution at 2-lane MIPI bus with complete user control over image quality.
Due to the sensor’s high resolution, the OV2311 offers exceptionally accurate gaze- and eye-tracking capabilities, and it achieves high near-infrared quantum efficiency to minimize active illumination power and reduce the system power requirements.
⚠️ KERNEL CAMERA DRIVER USED
This camera relies on kernel drivers to work – one kernel version, one camera driver. Up or downgrading your OS leads to a kernel bump, and you may need to re-install a matching driver.
- Sensors
- Sensor: Global Shutter OV2311 Monochrome
- Pixel size: 3 µm x 3 µm
- Active array size: 1600 x 1300
- Optical Format size: 1/2.9″
- Maximum image transfer rate: 1600 x 1300: 60 fps
- Support for image sizes: 1600 x 1300, 1280 x 720, 640 x 480
- Input clock frequency: 6~27 MHz
- Max S/N ratio: 37.4 dB
- Dynamic range: 68 dB
- Lens
- Lens Thread: M9 x 0.25P
- Lens Field of View(FoV): 55°(H)
- IR Sensitivity: without IR filter, sensitive to IR
- Camera Module
- Output interface: 2-lane MIPI
- Output formats: RAW 8/10 bit
- Minimum exposure time: 1 row period (11.3us at the resolution of 1600×1300 on Jetson Nano.)
Driver Features:
- Support Gray, Y10, Y16
- Support standard V4L2 framework, Video Nodes and Controls (Exposure, Gain and depending on camera parameters)
- Support External Trigger Global Shutter Camera
- Support Single Line Driver Installation Command
- Support OpenCV Friendly and Provides Source Code Demonstration
- Support Dual Camera Synchronization
Applications:
- Augmented and virtual reality
- Drones
- 3D imaging
- Machine vision
- Industrial bar code scanning
- Industrial automation
Jetvariety – MIPI Camera Modules for Jetson Nano/Xavier NX
Jetson Nano’s MIPI interface and MIPI connectors The Jetson Nano Developer Kit consists of two parts: The Computer on a Module (CoM), and the carrier board. The CoM supports high-speed MIPI interface, which is now a must-have for embedded vision applications. The carrier board of the Jetson Nano developer kit exposes the MIPI interface in […]
Project Jetvariety: How Arducam Makes it Possible to Use Any Camera Module on the Jetson Nano with One Kernel Driver for All
Introducing Project Jetvariety – Increase the Jetson Nano Camera Variety Today we are proud to introduce the Project Jetvariety (short for Jetson variety), which aims to quickly increase the variety of Jetson Nano cameras with our proprietary general-purpose camera solution. The Jetson Nano and Xavier NX only have official driver support of the Raspberry Pi […]
