Arducam IMX219 Auto Focus IR Sensitive (NoIR) Camera Module, drop-in replacement for Raspberry Pi V2 and NVIDIA Jetson Camera
  • Easy installation: Just detach the original stock IMX219 module onboard and re-attach this replacement
  • Motorized Focus Lens:The lens focus is programmable by software
  • Wide Application: Drones, robots, action cameras and 3D scanning applications
  • Camera board is not included in the package, please make sure you have the IMX219 Camera board before purchasing the product
This Arducam IMX219 camera module is designed mainly for Raspberry Pi V2 camera board and NVIDIA Jetson Board, replacing the default standard IMX219 camera module with the auto focus one. It can be used for drones, robots, action camera,s and 3D scanning applications. The highlight of this camera is that the lens focus is programmable by software, and Arducam team provides an open-source code to implement software auto-focus function for Jetson Board.
To learn more about autofocus with Raspberry Pi camera modules, we recommend you read Raspberry Pi Camera Autofocus: The Complete Guide.
KERNEL CAMERA DRIVER USED
This camera relies on kernel drivers to work – one kernel version, one camera driver. Please refer to the Supported JetPack Version for Different NVIDIA Jetson Platforms to ensure compatibility.
SUPPORTED PLATFORM DISCLAIMER
This camera is specifically designed for the official NVIDIA® Jetson™ Developer Kit by default and does not support third-party carrier boards.
  • Unmanned Aerial Vehicles (UAVs)
  • Building Drones
  • Autonomous Robotic Systems
  • Mobile Medical Imaging
  • Intelligent Video Analytics (IVA)
Image SensorIMX219
Still Resolution8 Megapixels
Video Modes1080p47, 1640 × 1232p41 and 640 × 480p206
Sensor Resolution3280 × 2464 pixels
Sensor image area3.68 x 2.76 mm (4.6 mm diagonal)
Pixel Size1.12 µm x 1.12 µm
Optical Size1/4"
IR Sensitivitywithout IR-cut filter, sensitive to IR light
Focus TypeProgrammable/Auto Focus
Focal Length2.8mm
F.NOF2.2
Field of View(FOV)65°(H)×51°(V)×77.6°(D)
Lens TypeStock Lens
Focus Distance80mm to infinity
Electrical & Mechanical
Peaking Current300mA
  • 1 x Arducam IMX219-AF Programmable/Auto Focus IR Sensitive (NoIR) Camera Module
    • The package does not include any Raspberry Pi motherboard.
    • The drop-in replacement module does not include FPC cables and any camera boards. And it requires the use of the Raspberry Pi V2 camera board to function properly.
    • The lenses of all camera modules are not interchangeable. Please contact sales in advance if you need to replace them.
    Note for Supported Raspberry Pi Boards and OS
    PlatformBookworm(rpicam)Bullseye(libcamera)Buster(raspistill)
    Raspberry Pi 5
    Raspberry Pi 4B / 3B+ / 3A+ / Zero / Zero 2 W
    Used on Pi
    8MP IMX219 Motorized Focus Camera Module
    Introduction Arducam 8MP IMX219 Motorized Focus Camera Modules are designed for you to control the focus via software, so you can see closer and see where you want to see. To learn more about autofocus with Raspberry Pi camera modules, we recommend you read Raspberry Pi Camera Autofocus: The Complete Guide. Models in this Series There […]
    Used on Jetson
    IMX219 – Motorized Focus Camera
    Introduction The autofocus camera is an advanced IMX219 camera module for Jetson Nano/Xavier NX board. It helps to focus the object in close range from 5cm~30cm, within this range the standard fixed focus camera can not get sharp focus and the image looks burry. All the focus procedure is controlled by the software without manually […]
    3D drawing_case.step
      Jetson_nano_cameras_8mp_imx219_arducam_blog_thumbnail
      Arducam Introduces 8MP IMX219 Auto Focus, Wide Angle, Zero-Distortion and Spy Camera to the NVidia Jetson Nano
      NVIDIA JETSON NANO AND ITS CAMERAS The Jetson Nano is a powerful single-board computer from NVidia. Featuring the extraordinary GPU performance, this NVidia development board is widely used in image processing applications like motion-tracking, face recognition and home surveillance camera systems, and a smart camera is a key to realizing all of them. However, currently, […]
      2 comments
      Selection Guide
      SKUProductResolutionColorShutterCamera boardMountIR sensitivityFocus
      B01610.3MP Monochrome Global Shutter0.3MPB/WGlobal shutter40mmStockVisible lightFixed Focus
      B01621MP Monochrome Global Shutter1MPB/WGlobal shutter40mmStockVisible lightFixed Focus
      B01651MP Monochrome Global Shutter M12 Mount1MPB/WGlobal shutter40mmM12Visible lightAdjustable
      B00315MP M125MPRGBrolling shutter36mmM12Visible lightAdjustable
      B00325MP CS Mount5MPRGBrolling shutter36mmCSVisible lightAdjustable
      B00335MP5MPRGBrolling shutter24mmStockVisible lightFixed Focus
      B0033+B00875MP with Pi Zero Cable5MPRGBrolling shutter24mmStockVisible lightFixed Focus
      B0033015MP NoIR5MPRGBrolling shutter24mmStockIR sensitiveFixed Focus
      B0033C5MP with case5MPRGBrolling shutter24mmStockVisible lightFixed Focus
      B0033R5MP with long Ribbon Cable5MPRGBrolling shutter24mmStockVisible lightFixed Focus
      B00355MP M12 NOIR5MPRGBrolling shutter36mmM12IR sensitiveAdjustable
      B0035035MP Switchable IR-cut with LED5MPRGBrolling shutter36mmM12Switchable IR filterAdjustable
      B00365MP CS Mount CS NOIR5MPRGBrolling shutter36mmCSIR sensitiveAdjustable
      B00555MP M12 Fisheye5MPRGBrolling shutter36mmM12Visible lightAdjustable
      B00665MP Cam5MPRGBrolling shutterspy camStockVisible lightFixed Focus
      B0066025MP NOIR5MPRGBrolling shutterspy camStockIR sensitiveFixed Focus
      B0066035MP Pi zero spy cam 605MPRGBrolling shutterspy cam ZeroStockVisible lightFixed Focus
      B0066045MP Pi zero spy cam 1205MPRGBrolling shutterspy cam ZeroStockVisible lightFixed Focus
      B0066055MP Pi zero spy cam 1605MPRGBrolling shutterspy cam ZeroStockVisible lightFixed Focus
      B01215MP AutoFocus5MPRGBrolling shutter40mmStockVisible lightProgrammable
      B01515MP Switchable IR-cut5MPRGBrolling shutter36mmM12Switchable IR filterAdjustable
      B01675MP5MP PTZ5MPRGBrolling shutter36mmF14Switchable IR filterVarifocal
      B01765MP AutoFocus mini5MPRGBrolling shutter24mmStockVisible lightProgrammable
      B01028MP CS8MPRGBrolling shutter36mmCSVisible lightAdjustable
      B01038MP M128MPRGBrolling shutter36mmM12Visible lightAdjustable
      B01228MP AutoFocus8MPRGBrolling shutter40mmStockVisible lightProgrammable
      B01528MP M12 NOIR8MPRGBrolling shutter36mmM12IR sensitiveAdjustable
      B01538MP CS NoIR8MPRGBrolling shutter36mmCSIR sensitiveAdjustable
      B01548MP M12 Switchable IR-cut8MPRGBrolling shutter36mmM12Switchable IR filterAdjustable
      B01678MP8MP PTZ8MPRGBrolling shutter36mmF14Switchable IR filterVarifocal
      B01808MP IMX219 replacement M12 170 Wide Angle8MPRGBrolling shutterSensor ModuleM12Visible lightAdjustable
      B01828MP IMX219 replacement Autofocus8MPRGBrolling shutterSensor ModuleStockVisible lightProgrammable
      B01848MP IMX219 replacement M12 Low Distortion8MPRGBrolling shutterSensor ModuleM12Visible lightAdjustable
      B01888MP IMX219 replacement M12 Low Distortion NoIR8MPRGBrolling shutterSensor ModuleM12IR sensitiveAdjustable
      B01908MP IMX219 replacement Autofocus NoIR8MPRGBrolling shutterSensor ModuleStockIR sensitiveProgrammable
      B10948MP IMX219 replacement M12 170 Wide Angle NoIR8MPRGBrolling shutterSensor ModuleM12IR sensitiveAdjustable
      B016313MP MIPI Camera13MPRGBrolling shutter40mmStockVisible lightFixed Focus
      B017416MP MIPI Camera16MPRGBrolling shutter40mmStockVisible lightFixed Focus
      B016418MP MIPI Camera18MPRGBrolling shutter40mmM12Visible lightAdjustable
      Raspberry Pi/NVIDIA Jetson
      Native Camera
      IMX219
      8MP
      MONO
      Auto Focus, High Speed
      Fixed Focus
