Arducam Mini 5MP OV5647 Camera Module for Raspberry Pi 4/3B+/3 (NoIR)
  • 5MP camera natively compatible with the official Raspberry Pi camera modules and motherboards
  • No IR filter, sensitive to Infrared light. Serve as a night vision camera with external light sources like IR LED illuminators
  • Work on libcamera commands and python scripts as you would expect
  • Ribbon cable for Pi Zero(B0107+B0087) and 200cm/6.5ft extension cable(U3848) for projects like 3D printers are sold separately
Notify Me
SKU: B003301 Categories: ,
The NoIR version of Arducam B0033 mini camera module for Raspberry Pi. This 5MP camera is natively compatible with the official Raspberry Pi camera modules and motherboards. It can be served as a night vision camera with external light sources like IR LED illuminators. It can also work on libcamera commands and python scripts as you would expect for a new project or drop-in replacement.
SensorOmnivision OV5647 sensor
Sensor size1/4” (OV5647)
Resolution5MP 2592×1944
Video1080p 30 fps, 720p 60fps, 480p 90fps
Field of View (FOV)54°(H), 41°(V)
Focus TypeFixed Focus
Focus Length3.60mm
Focus Distance1 m to infinity
Full-frame SLR lens equivalent35 mm
IR SensitivityNoIR filter, sensitive to IR
Dimension25×24 mm
Peak Current300mA
  • 1pcs 5MP Mini Camera OV5647 Sensor NOIR version for Raspberry Pi official Board
  • 1pcs 15cm 15pin FPC cable
User Guide. pdf
OV5647 NoIR Camera for Raspberry Pi Now Released
  The Pi NoIR is a Raspberry Pi camera module with no Infrared filter for night time and low light photography using an Infrared light. Useful for wildlife research, science projects, night time security or making artistic photo’s. The Raspberry Pi camera module has been used for many things such as a security camera, for time […]
1 comment
Selection Guide
SKUProductResolutionColorShutterCamera boardMountIR sensitivityFocus
B01610.3MP Monochrome Global Shutter0.3MPB/WGlobal shutter40mmStockVisible lightFixed Focus
B01621MP Monochrome Global Shutter1MPB/WGlobal shutter40mmStockVisible lightFixed Focus
B01651MP Monochrome Global Shutter M12 Mount1MPB/WGlobal shutter40mmM12Visible lightAdjustable
B00315MP M125MPRGBrolling shutter36mmM12Visible lightAdjustable
B00325MP CS Mount5MPRGBrolling shutter36mmCSVisible lightAdjustable
B00335MP5MPRGBrolling shutter24mmStockVisible lightFixed Focus
B0033+B00875MP with Pi Zero Cable5MPRGBrolling shutter24mmStockVisible lightFixed Focus
B0033015MP NoIR5MPRGBrolling shutter24mmStockIR sensitiveFixed Focus
B0033C5MP with case5MPRGBrolling shutter24mmStockVisible lightFixed Focus
B0033R5MP with long Ribbon Cable5MPRGBrolling shutter24mmStockVisible lightFixed Focus
B00355MP M12 NOIR5MPRGBrolling shutter36mmM12IR sensitiveAdjustable
B0035035MP Switchable IR-cut with LED5MPRGBrolling shutter36mmM12Switchable IR filterAdjustable
B00365MP CS Mount CS NOIR5MPRGBrolling shutter36mmCSIR sensitiveAdjustable
B00555MP M12 Fisheye5MPRGBrolling shutter36mmM12Visible lightAdjustable
B00665MP Cam5MPRGBrolling shutterspy camStockVisible lightFixed Focus
B0066025MP NOIR5MPRGBrolling shutterspy camStockIR sensitiveFixed Focus
B0066035MP Pi zero spy cam 605MPRGBrolling shutterspy cam ZeroStockVisible lightFixed Focus
B0066045MP Pi zero spy cam 1205MPRGBrolling shutterspy cam ZeroStockVisible lightFixed Focus
B0066055MP Pi zero spy cam 1605MPRGBrolling shutterspy cam ZeroStockVisible lightFixed Focus
B01215MP AutoFocus5MPRGBrolling shutter40mmStockVisible lightProgrammable
B01515MP Switchable IR-cut5MPRGBrolling shutter36mmM12Switchable IR filterAdjustable
B01675MP5MP PTZ5MPRGBrolling shutter36mmF14Switchable IR filterVarifocal
B01765MP AutoFocus mini5MPRGBrolling shutter24mmStockVisible lightProgrammable
B01028MP CS8MPRGBrolling shutter36mmCSVisible lightAdjustable
B01038MP M128MPRGBrolling shutter36mmM12Visible lightAdjustable
B01228MP AutoFocus8MPRGBrolling shutter40mmStockVisible lightProgrammable
B01528MP M12 NOIR8MPRGBrolling shutter36mmM12IR sensitiveAdjustable
B01538MP CS NoIR8MPRGBrolling shutter36mmCSIR sensitiveAdjustable
B01548MP M12 Switchable IR-cut8MPRGBrolling shutter36mmM12Switchable IR filterAdjustable
B01678MP8MP PTZ8MPRGBrolling shutter36mmF14Switchable IR filterVarifocal
B01808MP IMX219 replacement M12 170 Wide Angle8MPRGBrolling shutterSensor ModuleM12Visible lightAdjustable
B01828MP IMX219 replacement Autofocus8MPRGBrolling shutterSensor ModuleStockVisible lightProgrammable
B01848MP IMX219 replacement M12 Low Distortion8MPRGBrolling shutterSensor ModuleM12Visible lightAdjustable
B01888MP IMX219 replacement M12 Low Distortion NoIR8MPRGBrolling shutterSensor ModuleM12IR sensitiveAdjustable
B01908MP IMX219 replacement Autofocus NoIR8MPRGBrolling shutterSensor ModuleStockIR sensitiveProgrammable
B10948MP IMX219 replacement M12 170 Wide Angle NoIR8MPRGBrolling shutterSensor ModuleM12IR sensitiveAdjustable
B016313MP MIPI Camera13MPRGBrolling shutter40mmStockVisible lightFixed Focus
B017416MP MIPI Camera16MPRGBrolling shutter40mmStockVisible lightFixed Focus
B016418MP MIPI Camera18MPRGBrolling shutter40mmM12Visible lightAdjustable
Native Camera
OV5647
5MP
MONO
High Speed
Fixed Focus
