Arducam 2MP Sony STARVIS IMX462 Ultra Low Light Manual Focus USB 3.0 Camera Module
$ 135.99$ 150.99
  • Plug and play
  • Based on 2MP IMX462, maximum still resolution of 1920*1080
  • Programmable frame rates, reach up to 80fps@720p
  • M12 manual focus lens for Precision focus and wide 98°(D) view.
SKU: B0496 Categories: ,
Arducam’s USB 3.0 camera series introduces the IMX462 Manual Focus model. With a 1/2.8″ Starvis CMOS, it achieves a maximum still resolution of 1920×1080.
Enhanced with a 98°(D) starlight lens for low-light imaging, this device allows manual focus to capture precise and accurate images.
  • Machine Vision
  • Video Surveillance
  • 3D Scanning and Metrology
  • Live Streaming
  • Video Conferencing
  • Superior Imaging: Utilizes a Starvis back-illuminated IMX462 image sensor that delivers low-light sharpness at a maximum still resolution of 1920×1080.
  • Flexible Frame Rates: Programmable your desired frame rates, even reaching 80fps at 720p.
  • Advanced Image Enhancement: On-board ISP features proprietary technologies—de-Bayer, gamma, BLC, AE, AWB, CCM, RGB2YUV—ensuring top-notch image quality.
  • Precision and Perspective: Attain optimal clarity with M12 manual focus and a broad 98°(D) field of view for comprehensive monitoring and recording.
  • Plug and Play: Effortless compatibility with Windows and Linux through plug-and-play functionality, eliminating the need for additional drivers.
SensorIMX462
Still Resolution2 Megapixels
Color Filter TypeColor
Shutter TypeRolling
Optical Size1/2.8″
Output FormatYUY2
Pixel Size2.9 µm x 2.9 µm
Sensor Active Area1920H)×1080(V)
Frame Rate (USB 3.0)1920*1080@60fps, 1280*720@80fps
Frame Rate (USB 2.0)1280*720@10fps
Focus TypeManual Focus
FOV98°(D)×85°(H)×69°(V)
Lens MountM12
F.NOF1.0
E.F.L3.9mm
IR SensitivityIntegral IR-cut Filter, visible light only
Default Focus Range3m-∞
InterfaceUSB 3.2 Gen 1 device, backward compatible with USB 2.0 hosts
ConnectorType-C reversible interface connector
UVC CompliantNo additional drivers required
Operating Voltage5 V +/- 5%
Operating Temp.32°F-158°F (0°C to 70°C)
Power Requirements Max: 1.6W  , Min: 0.8W
Camera Board Size34×34 mm
Supported OSWindows, Linux
Recommend Sample ApplicationPotPlayer for Windows, qv4l2 for Linux
UVC ControlsBrightness, Contrast, Saturation, White Balance (Auto/Manual), Gain, Backlight Comp, Exposure (Manual/Auto)
  • 1 x IMX462 USB3 Camera with Back Cover and Tripod Adapter
WeightN/A
x86 PC
UVC USB Camera
USB 3.0
IMX462
YES
2MP
Low Light
Camera Enclosure
With Enclosure, Without Enclosure
