Arducam 5MP OV5647 Miniature Camera Module with M6 Lens and Flexible Cable for Pi Zero,Pi 5 and Pi Compute Module
Arducam 5MP OV5647 1080P Camera Module with Acrylic Case for Raspberry 5/4/3B+/3 and More
Arducam 5MP OV5647 Camera for Monitoring 3D Printer, with 3.28FT/100CM Long Extension Flex Ribbon Cable for Raspberry Pi
B0033R
  • 5MP camera module for 3D printer projects with Raspberry Pi
  • Natively compatible with the official Raspberry Pi camera modules and motherboards
  • Used on Raspbian 3D printer monitoring, surveillance camera or other Pi cam projects
  • 100cm/3.28ft extension cable included, long enough for mounting the camera
  • Work on libcamera commands and python scripts as you would expect for a new project or drop-in replacement
was $13.99 Special Price $8.99
To meet the growing demand for Raspberry Pi compatible camera modules. The Arducam team has now released another fully compatible add-on mini camera module for the Raspberry Pi series boards.
The board itself is small, about 25mm x 24mm, making it ideal for mobile or other applications where size and image quality are important. It connects to the Raspberry Pi via a short ribbon cable. The camera is connected to the BCM2835/BCM2836 processor on the Pi via a CSI bus that runs along the ribbon cable that connects the camera board to the Pi.
The sensor itself has a native resolution of 5 megapixels and has an onboard fixed focal length lens. In terms of still images, the camera is capable of capturing 2592 x 1944 pixel still images and also supports 1080p30fps, 720p60fps and 640x480p60/90fps video.
  • Raspbian
  • 3D printer monitoring
  • Surveillance camera
  • PC multimedia
  • Other Pi camera projects
  • Digital still cameras,etc.
Sensor size 1/4” (OV5647)
Resolution 5MP 2592×1944
Field of View (FOV) 54°(H), 41°(V)
Full-frame SLR lens equivalent 35 mm
Dimension 25×24 mm
Peak Current 300mA
  • 2 x 15-15 pin flex ribbon cables (15cm/100cm) for Raspberry Pi A&B series
  • 1 x 15-22 pin flex ribbon cable (15cm) for Raspberry Pi Zero
  • 1x OV5647 Camera Module
  • Raspberry Pi board is not included
    Raspberry Pi 5 √ √
You can purchase this item from Arducam distributors or Arducam’s Amazon store
Selection Guide
Edit
