Arducam xISP - Swift, Pre-tuned ISP, Global shutter 2.3MP MIPI Camera for NVIDIA® Jetson™ ORIN™ NX / Orin™ Nano   / Renesas RZ/V2H
Arducam xISP - Klarity, Pre-tuned ISP, 20MP High Sensitivity MIPI Camera for NVIDIA® Jetson™ ORIN™ NX / Orin™ Nano  / Renesas RZ/V2H
Arducam xISP - Klarity, Pre-tuned ISP, 1/1.8" Mono High Sensitivity MIPI Camera for NVIDIA® Jetson™ ORIN™ NX / Orin™ Nano / Renesas RZ/V2H
B0544
  • Pre-tuned ISP: Armed with Arducam proprietary external ISP (ImageEK) on camera board
  • Performance Sensor: Onsemi Hyperlux LP AR2020 Mono, excellent for Low-Light Performance and enhanced NIR response.
  • User-Friendly: All xISP MIPI cameras utilize universal drivers and standard video device V4L2 nodes.
  • Cross-Platform Support: Jetson Orin NX/Orin Nano are already supported. The open source camera driver enables users to adapt the cameras to other Jetson platform/kernel version by themselves.
  • Good for PoC: Suitable for your embedded vision project requiring ISP support and low light environment performance
  • [Renesas Support] Supports the Renesas RZ/V2H platform.
$249.99
The Arducam xISP - Klarity AR2020M is a cutting-edge 1/1.8" mono high-sensitivity MIPI camera designed for the NVIDIA® Jetson™ ORIN™ NX and Orin™ Nano platforms. Equipped with Arducam's proprietary external ISP, ImageEK, this camera features the Onsemi Hyperlux LP AR2020 Mono sensor, which excels in low-light performance and enhances near-infrared (NIR) response, making it ideal for specialized imaging applications.
Arducam ImageEK is our proprietary flexible external ISP solution tailored for embedded vision proof of concept (PoC) applications. Designed to unleash the full potential of high-performance image sensors on mainstream embedded platforms, ImageEK provides users with powerful and easy-to-use image processing capabilities, enabling the development of more advanced and versatile applications.
  • Videoconferencing
  • Virtual & Augmented Reality
  • Machine Vision
  • Retail Analytics
  • Biometrics
  • Robotics
  • IoT Devices
  • Pre-tuned ISP: The Darksee camera is equipped with Arducam's proprietary external ISP (ImageEK) integrated directly on the camera board, ensuring optimized image processing for superior output.
  • Performance Sensor: Utilizes the Onsemi Hyperlux LP AR2020 Mono sensor, providing excellent low-light performance and enhanced NIR response.
  • Increased Flexibility: The FPGA-based ISP offers greater flexibility, significantly offloading ISP support from SoC vendors.
  • User-Friendly Design: Utilizes universal camera drivers and standard video device nodes from the native V4L2 interface, along with a single kernel driver for all cameras, simplifying integration.
  • Diverse Sensor Options: Supports a wide selection of high-performance sensors, accommodating various applications, including options for resolutions up to 50MP.
  • Cross-Platform Support: Thanks to the open-source camera driver, xISP cameras ensure compatibility across different platforms while preserving end users’ R&D design assets during camera or platform transitions.
  • Customization Support: Arducam provides flexible and timely customized ISP R&D support to cater to specific project needs.
  • Accelerated Time to Market: Off-the-shelf solutions and quick customization services enable users to bring products to market faster and focus on their projects more efficiently.
  • Cost-Effective Solutions: Users can select different solutions at various stages of proof of concept (PoC) and small production runs, resulting in a lower total cost.
  • [Renesas Platform Support] This camera has supported the Renesas RZ/V2H platform since November 2025.
Sensor AR2020
Still Resolution 20 Megapixels
Color Filter Type Mono
Optical Size 1/1.8"
Output Format UYVY
Pixel Size 1.4× 1.4 μm
Sensor Active Area 5120(H) × 3840(V)
Frame Rate 5120×3840@8fps;
3840×2160@20fps
2560×1920@30fps
1920×1080@60fps
1280×960@90fps
1280×720@120fps
FOV 95°(D) × 82°(H) × 66°(V)
Lens Mount M12 (S-mount)
F.NO F1.65±10%
E.F.L 4.9±5%mm
Default Focus Range 3m-∞
Operating Voltage 3.3V
Operating Temp. 0℃~60℃
Power Requirements MAX:3.3V*350mA
Camera Board Size 34 × 34 mm
Supported OS JetPack6.1 L4T36.4.0
Supported Platform* NVIDIA® Jetson™ ORIN™ NX / Orin™ nano
Supported Camera Controls Demosaic, Gamma correction, Lens shading correction(Option), DPC(Defective pixel correction), Auto White balance, Auto Exposure, Auto Gain, RGB2YUV, Black Level Calibration(BLC), CCM(Color correction matrix)
Recommend Sample Application Python Demo for Image Capture & Preview
V4L2 Linux driver for Video preview & Still Image capture & Camera controls via IOCTLs
Gstreamer-1.0 support for video recording and network streaming
  • *Please note: Due to compatibility limitations, the camera currently supports only the interface nearest to the power supply: Orin Nano supports CAM1, while Orin NX supports CAM0.
  • Package Including
    • 1× MIPI ISP Camera
    • 1× 15cm 22-22pin FPC
    • This camera is currently compatible only with NVIDIA® Jetson™ ORIN™ NX / Orin™ Nano.
    • This product kit does not include NVIDIA Jetson development boards and is not compatible with third-party carrier boards.
    • Tripod is not included in the package, please check UB0216 for additional purchase.
