Arducam xISP - Darksee, Pre-tuned ISP, 1/1.2
Arducam xISP - Darksee, Pre-tuned ISP, 1/1.2" Low Light MIPI Camera for NVIDIA® Jetson™ ORIN™ NX / Orin™ Nano / Renesas RZ/V2H
Arducam xISP - Darksee, Pre-tuned ISP, 2MP Low Light MIPI Camera for NVIDIA® Jetson™ ORIN™ NX / Orin™ Nano / Renesas RZ/V2H
B0546
  • Pre-tuned ISP: Armed with Arducam proprietary external ISP (ImageEK) on camera board
  • Low Light Performance: Equipped with SONY STARVIS image sensor IMX462
  • User-Friendly: All xISP MIPI cameras utilize universal drivers and standard video device V4L2 nodes.
  • Cross-Platform Support: Jetson Orin NX/Orin Nano are already supported. The open source camera driver enables users to adapt the cameras to other Jetson platform/kernel version by themselves.
  • Good for PoC: Suitable for your embedded vision project requiring ISP support and low light environment performance
  • [Renesas Support] Supports the Renesas RZ/V2H platform.
$153.99
The Arducam xISP - Darksee IMX462 is a cutting-edge 2MP low-light MIPI camera designed initially for the NVIDIA® Jetson™ ORIN™ NX and Orin™ Nano platforms. This innovative camera system incorporates Arducam's proprietary ImageEK, an external ISP solution, to deliver exceptional performance in low-light environments. The combination of advanced imaging technology and ImageEK's powerful processing capabilities makes the Darksee an ideal choice for embedded vision projects.
Arducam ImageEK is our proprietary flexible external ISP solution tailored for embedded vision proof of concept (PoC) applications. Designed to unleash the full potential of high-performance image sensors on mainstream embedded platforms, ImageEK provides users with powerful and easy-to-use image processing capabilities, enabling the development of more advanced and versatile applications.
  • Facility surveillance
  • Street monitoring
  • Traffic monitoring
  • Dashboard cameras
  • Home security systems
  • Robotics
  • IoT Devices
  • Pre-tuned ISP: The Darksee camera is equipped with Arducam's proprietary external ISP (ImageEK) integrated directly on the camera board, ensuring optimized image processing for superior output.
  • Low Light Performance: Featuring the SONY STARVIS IMX462 image sensor, the Darksee excels in low-light conditions, providing clear and detailed images even in challenging lighting scenarios.
  • User-Friendly Design: Utilizes universal camera drivers and standard video device nodes from the native V4L2 interface, along with a single kernel driver for all cameras, simplifying integration.
  • Increased Flexibility: The FPGA-based ISP offers greater flexibility, significantly offloading ISP support from SoC vendors.
  • Diverse Sensor Options: Supports a wide selection of high-performance sensors, accommodating various applications, including options for resolutions up to 50MP.
  • Cross-Platform Support: Thanks to the open-source camera driver, xISP cameras ensure compatibility across different platforms while preserving end users’ R&D design assets during camera or platform transitions.
  • Customization Support: Arducam provides flexible and timely customized ISP R&D support to cater to specific project needs.
  • Accelerated Time to Market: Off-the-shelf solutions and quick customization services enable users to bring products to market faster and focus on their projects more efficiently.
  • Cost-Effective Solutions: Users can select different solutions at various stages of proof of concept (PoC) and small production runs, resulting in a lower total cost.
  • [Renesas Platform Support] This camera has supported the Renesas RZ/V2H platform since November 2025.
Sensor IMX462
Still Resolution 2 Megapixels
Optical Size 1/2.8"
Output Format UYVY
Pixel Size 2.9 µm x 2.9 µm
Sensor Active Area 1920H)×1080(V)
Frame Rate 1920×1080@60fps, 1280×720@60fps
FOV 98°(D)×85°(H)×69°(V)
Lens Mount M12
F.NO F1.0
E.F.L 3.9mm
Default Focus Range 3m-∞
Operating Voltage 3.3V
Operating Temp. 0℃~70℃
Power Requirements MAX:3.3V*350mA
Camera Board Size 34 × 34 mm
Supported OS JetPack6.1 L4T36.4.0
Supported Platform* NVIDIA® Jetson™ ORIN™ NX / Orin™ nano
Supported Camera Controls Demosaic, Gamma correction, Lens shading correction(Option), DPC(Defective pixel correction), Auto White balance, Auto Exposure, Auto Gain, RGB2YUV, Black Level Calibration(BLC), CCM(Color correction matrix)
Recommend Sample Application Python Demo for Image Capture & Preview
V4L2 Linux driver for Video preview & Still Image capture & Camera controls via IOCTLs
Gstreamer-1.0 support for video recording and network streaming
  • *Please note: Due to compatibility limitations, the camera currently supports only the interface nearest to the power supply: Orin Nano supports CAM1, while Orin NX supports CAM0.
  • Package Including
    • 1× MIPI ISP Camera
    • 1× 15cm 22-22pin FPC
    • This camera is currently compatible only with NVIDIA® Jetson™ ORIN™ NX / Orin™ Nano.
    • This product kit does not include NVIDIA Jetson development boards and is not compatible with third-party carrier boards.
    • Tripod is not included in the package, please check UB0216 for additional purchase.
