Arducam Adjustable Tripod Stand with Bubble Level Indicator for Raspberry Pi High Quality Camera
Arducam Tripod Stabilizer for Raspberry Pi High Quality Camera, Variable Height Portable Camera Tripod Stand
Arducam Variable Height Tripod Stand for Raspberry Pi High Quality Camera, with 360 Ball Head
UB0219
$16.99
Why a mini tripod is necessary for The Rpi High Quality Camera?
The official Rpi HQ Camera module and a C-mount lens together weigh 164g, which is the equivalent of 4 Rpi 4 boards.
It’s way too heavy as an embedded camera, and your good old third hands won’t work anymore, you need something more bearable to hold the HQ camera up in proper ways, you need tripods.
Arducam selected and tested a wide range of optimal tripods and find this mini and high-cost performance tripod, which is perfect for the Rpi HQ cameras.
  • 1/4" Standard Mounting Screw: hassle-free fitting the Raspberry Pi High Quality Camera Board, DSLR camera and other devices with the tripod mount of 1/4”-20.
  • Ball Head: Easy to twist to allow your camera to get a 360-degree vision; Twist lock with contoured knob makes your camera fixed in position.
  • 3 Variable Heights: Come with mini rotary knob head, rotate to switch to different heights and fix the leg as you need.
  • Durable and Reliable: Made of high quality ABS, fadeless, waterproof and rust-resistant; Antiskid silicone footpads keep the tripod from slipping
  • Mini and Lightweight: Only about 0.29lb/130g with folded length 8”/205mm, easy to carry and store.
  • Recommended max load weight is 6.6 lbs (3kg) for optimal performance
    • 1pcs variable height tripod with ball head UB0219
