Arducam qb.R-OwlSight 64MP AF All-in-One Camera Kit (Raspberry Pi CM5)
B0617
  • 64MP OwlSight Resolution: Ultra-high-def sensor for extreme detail and precision inspection.
  • Built-in Pi CM5: Integrated Raspberry Pi CM5 for powerful, standalone edge computing.
  • Fast Autofocus: Ensures sharp imaging instantly across various distances.
  • Industrial "qb" Design: Ultra-compact, rugged cube form factor for tight-space integration.
  • PoE & USB-C: Flexible power and data via Power over Ethernet or standard USB-C.
  • OEM Customization: Fully tailorable hardware and firmware for industrial deployments.
SAMPLE PRICE
$439.99
VOLUME PRICE
The Arducam qb.R-OwlSight marks a new era in standalone vision systems. As part of the qb collection, this camera reimagines high-performance imaging by packing a 64MP OwlSight sensor and a Raspberry Pi Compute Module 5 (CM5) into a single, sleek, industrial cube. This "All-in-One" philosophy eliminates the need for separate controllers and messy cabling, providing a ready-to-use edge AI platform straight out of the box. Arducam stands behind the qb series with a focus on industrial reliability and long-term support. We provide a bridge from initial prototype to mass production, offering extensive customization options and a stable supply chain. Whether you are building a standalone smart sensor or a complex vision network, the qb.R-OwlSight delivers the flexibility and power needed for modern industrial deployment.
  • Automated Optical Inspection (AOI): Identify microscopic defects on PCBs or high-speed production lines with 64MP precision.
  • Edge AI Vision: Run complex machine learning models (object detection, classification) directly on the camera using the CM5.
  • Smart City & Traffic Monitoring: High-resolution capture for license plate recognition (LPR) and environmental monitoring via PoE.
  • Laboratory & Medical Imaging: Compact, autofocus-enabled standalone camera for slide scanning and documentation.
  • Digital Twinning & Photogrammetry: Capture ultra-detailed textures and geometry for high-fidelity 3D modeling.
  • OwlSight 64MP: Seeing the Unseen Our OwlSight technology provides a massive 64-megapixel canvas. This allows users to crop into specific areas of interest without losing the clarity required for AI analysis, making it a cost-effective alternative to multi-camera setups.
  • The Power of Raspberry Pi CM5 By embedding the latest CM5, the qb.R-OwlSight functions as a full Linux computer. It handles image acquisition, processing, and data transmission internally, significantly reducing system latency and complexity.
  • Industrial "qb" Form Factor The "qb" series isn't just about looks—its cube-shaped industrial housing is designed for heat dissipation and durability. Its small footprint makes it ideal for mounting on robotic arms or inside narrow machinery.
  • Single-Cable Efficiency with PoE With Power over Ethernet (PoE) support, you can transmit power and high-speed data over a single cable up to 100 meters. This simplifies installation in warehouses, factories, and outdoor environments.
  • Total Customization & Flexibility Arducam understands that one size doesn't always fit all. The qb.R-OwlSight is designed for modularity; we offer customization for lenses, enclosures, and specialized firmware to ensure the camera fits your exact project requirements.
Sensor OV64A40
Resolution 64 Megapixels
Chroma Color
Optical Format 1/1.32"
Output Format JPEG/YUV/RGB/RAW10
Pixel Size 1.008 µm x 1.008 µm
Sensor Active Area 9248(H)×6944(V)
Sensor Image Area 6.29 mm x 4.71 mm (7.86 mm diagonal)
Maximum Frame Rate 9152×6944@2fps, 8000×[email protected]; 4624×[email protected], 3840×[email protected]; 2312×[email protected], 1920×1080@45fps
Focus Type Autofocus
FOV 84°(D)×68°(H)×56°(V)
Lens Mount Stock Lens Mount
F.NO F1.9
E.F.L 6.65mm
Default Focus Distance 12cm-INF
Controller Properties
Controller Module Raspberry Pi Compute Module 5, CM5004016
Processor Broadcom BCM2712
RAM Memory 4GB
Storage 16GB of eMMC Flash Storage
Wi-Fi Connectivity Not Available
Bluetooth Connectivity Not Available
Interface PoE/USB-C
Network Support Ethernet
Supported OS Raspberry Pi OS
Max Exposure Time Low Speed Mode - 9152×6944: 1173.95(s) High Speed Mode: 9152×6944: 910.88(s) See fully details here
Supported Platform Raspberry Pi CM5 inside
Operating Voltage USB-C: 5.1V/3.0A PoE Power Input: IEEE 802.3at PoE/50-57V 600mA
Power Consumption (Typical, Maximum) Typical: N/A Max:15W
Overall Weight (Net) 168g
Camera Board Size 25x24 mm
Overall Size 60x50x40 mm
Temperature range (Storage) -14°F-167°F (-10°C to +75°C)
Certification CE/RoHS
  • 1 x Arducam qb.R-OwlSight 64MP AF Camera All-in-one Kit with RPI CM5 inside
  • This product kit includes the Raspberry Pi CM5 preloaded with Specific OS. It is recommended to use only this platform.
  • For optimal performance, we suggest using the official Raspberry Pi 27W power supply.
