Arducam 2.2MP Mira220 RGB-IR Global Shutter USB3.0 Camera Evaluation Kit
Arducam 2MP OV2311 Monochrom Global Shutter USB3.0 Camera Evaluation Kit with M12 Lens
Arducam OV7251 0.3MP Global Shutter USB Camera Evaluation Kit - 1/7.5-inch Monochrome Camera Module with USB3.0 Camera Shield Plus
EK022
Note:
  • The Camera Evaluation Kit needs a configuration file (sent via shipping notice) and isn’t plug-and-play.
  • About External Trigger Mode: This camera module supports the development of external trigger mode function. If you have relevant requirements, please contact Arducam sales for customization.
  • $215.99
    The Arducam monochrome (B&W) global shutter VGA resolution OV7251 MIPI camera module is mainly designed for Raspberry Pi boards, and it can be connected directly to RPi’s CSI-2 camera interface without additional hardware. This camera is based on a 1/7.5-inch Omnivision OV7251 image sensor which adopts OmniPixel3-GS™ technology to provide full-frame, sub-sampled, and windowed 8/10-bit MIPI images, and capable of operating at up to 100fps in VGA resolution with complete user control over image quality.
    The sensor's global shutter and excellent low-light sensitivity allow it to be used for any application that needs gesture detection, head and eye tracking, and depth and motion detection.
    Features:
    • Sensor: Monochrome global shutter OV7251
    • Pixel Size: 3 μm x 3 μm
    • Active array size: 640*480
    • Optical Size: 1/7.5 inch
    • EFL: 1.3mm
    • F.NO: 2.2
    • IR Sensitivity: build-in 650nm IR cut filter (Check IR sensitive version with SKU EK028)
    • FOV: D86.5 Deg./H72.9 Deg./V57.7 Deg.
    • Focusing Range: 65mm ~ infinite
    • Output interface: USB 3.0
    • Output formats: 8/10-bit BW RAW
    • Maximum image transfer rate: 640 x 480: 210 fps
    • Board Size: 40mm x 40mm
    Application:
    • Cellular phones
    • Toys
    • Tablets
    • Machine vision
    • ARM/FPGA/DSP based platforms
    Package Including:
    • 1 pcs Arducam OV7251 1/7.5-inch Monochrome Camera Module
    • 1 pcs Arducam USB3.0 Camera Shield plus
    • 1 pcs USB3 Cable
    Additional Resources:
