Arducam 2MP OV2311 Global shutter camera module is mainly designed for Raspberry pi boards, and it can be connected directly to RPi’s CSI-2 camera interface without additional hardware. This camera is based on 1/2.9-inch Omnivision OV2311 image sensor which adopts OmniPixel3-GS™ technology to provide full-frame, sub-sampled, and windowed 8/10-bit MIPI images, and capable of operating at up to 60fps in full resolution at 2-lane MIPI bus with complete user control over image quality.
Due to the sensor's high resolution, the OV2311 offers exceptionally accurate gaze- and eye-tracking capabilities, and it achieves high near-infrared quantum efficiency to minimize active illumination power and reduce the system power requirements.
Features:
Sensors
Sensor: Global Shutter OV2311 Monochrome
Pixel size: 3 µm x 3 µm
Active array size: 1600 x 1300
Optical Format size: 1/2.9"
Maximum image transfer rate: 1600 x 1300: 60 fps
Support for image sizes: 1600 x 1300, 1280 x 720, 640 x 480
Input clock frequency: 6~27 MHz
Max S/N ratio: 37.4 dB
Dynamic range: 68 dB
Lens Thread: M12 x 0.5P
Field of View(FoV): 83°(H)
IR Sensitivity: without IR Filter, IR sensitive
Camera Module
Output interface: 2-lane MIPI
Output formats: RAW 8/10 bit
Minimum exposure time: 1 row period (11.3us at the resolution of 1600x1300 on Raspberry Pi)
