In order to meet the new demands of the lens to work with Raspberry Pi High Quality Camera, Arducam selected and tested a wide range of M12 mount lenses from long focus to wide angle for shooting on your Rpi HQ cameras. It’s now much easier for you to get the best lens you’ll need, and we will keep the lens list growing in the near future.
The including CS lens mount and C-CS adapter ring can be used for microscopy with reversed mounted lens on Raspberry Pi V1 and V2 camera. For more details, you can refer to this link: https://www.raspberrypi.org/forums/viewtopic.php?f=43&t=210605&p=1675030#p1675030
| SKU | LN036 | LN024 | LN053 | LN033 | LN056 | LN031 |
| Part No: | M2025ZM02 | M2306ZM13 | M23390H08 | M23356H09 | M23272M14 | M25156H18 |
| Optical Format | 1/2.3'' | 1/2.3'' | 1/2.3'' | 1/2.3'' | 1/2.3'' | 1/2.3'' |
| EFL(mm) | 25.00 | 6.00 | 3.90 | 3.56 | 2.27 | 1.56 |
| BFL(mm) | 5.20 | 7.56 | 4.49 | 5.92 | 3.01 | 4.30 |
| Construction | 6G | 6G+IR | 6G+IR | 4G3P+IR | 8G+IR | 6G+IR |
| F/NO | 2.0 | 2.0 | 2.8 | 2.5 | 2.5 | 2.0 |
| HFOV on 1/2.3‘’ Cam | 20° | 50° | 75° | 90° | 140° | 180° |
| IR filter | No IR filter | 650 IR filter | 650 IR filter | 650 IR filter | 650 IR filter | 650 IR filter |
| MOD | 0.20m | 0.30m | 0.30m | 0.20m | 0.20m | 0.20m |
| Size(mm) | 17 x 21 | 16x 16.41 | 14x 18.67 | 14x 16.3 | 17.2x 22 | 20x 17.3 |
