Arducam CS-Mount Lens for Raspberry Pi High Quality Camera, 25mm Focal Length with Manual Focus
Arducam Lens for Raspberry Pi High Quality Camera, Wide Angle CS-Mount Lens, 6mm Focal Length with Manual Focus
LN029
  • The Wise Alternative – Another cost-effective choice that adds up to you Raspberry Pi High Quality Camera Module, with 6mm focal length and manual focus
  • Qualified Arducam – Arducam has been selecting and testing CS lenses on the Raspberry Pi cameras since the V1 camera era. Check B0032 if you want a 5MP Pi camera with CS Lens, and contact us to customized 8MP Pi cameras with CS lenses.
  • Other Specs – 65 degrees Horizontal Field of View (HFoV), 1/2″ Lens Optical Format, F/1.2, Dimension: Φ28×26mm, Weight: 50.5g
$15.99
In order to meet the new demands of the lens to work with Raspberry Pi High Quality Camera, Arducam selected and tested a wide range of CS-mount and C-mount optimal lenses from long focus to wide angle for shooting on your Rpi HQ cameras. It’s now much easier for you to get the best lens you’ll need, and we will keep the lens list growing in the near future.
    Lens Specification
    • Model No: CS1806ZM06
    • Optical Format: 1/1.8”
    • Focal Length: 6mm
    • Aperture (F): F1.4
    • Field of View (FOV): 65° (H)
    • Mount: CS-Mount
    • Back Focal Length: 8.03mm
    • MOD: 0.2m
    • Dimension: Φ28×28.5mm
    • Weight: 47g
    • 1pcs 1/1.8″ CS-mount CS1806ZM06 6mm Focal Length Camera Lens
