Arducam IMX219 Visible Light Fixed Focus Camera Module for NVIDIA® Jetson AGX Orin/Orin Nano/Orin NX
Arducam 8MP IMX219 Wide Angle Camera Module for NVIDIA® Jetson Orin Series
B034201
  • [2-lane/4-lane Support] Adopt MIPI CSI-2 interface, supporting 2lane/4lane output configurations.
  • [Native to NVIDIA Jetson] No need to install additional driver for this camera
  • [Easy to Set-Up] Just simply connect the camera and NVIDIA Jetson with a FPC cable
  • [Mini Size] hassle-free upgrades to your existing projects.
  • [Wide Compatibility] Compatible with NVIDIA Jetson Orin Nano/NX.
SAMPLE PRICE
$26.99
VOLUME PRICE
No less than the Raspberry Pi official camera V2, this camera module is also equipped with a high-definition IMX219 8MP sensor for shooting HD video and still images. It is excellent in image quality, color fidelity, and low light. For beginners, this is a very easy camera module to get started; for advanced players, this camera module has more knowledge that you should explore and DIY. Designed for the NVIDIA Jetson platforms, this camera requires no driver downloads. It features a default 2-lane driver and supports 4-lane expansion. Equipped with an ultra-wide-angle M12 lens for a wider field of view.
  • Unmanned Aerial Vehicles (UAVs)
  • Building Drones
  • Autonomous Robotic Systems
  • Mobile Medical Imaging
  • Intelligent Video Analytics (IVA), etc..
  • High-Speed Data Interface: Standard 2-lane MIPI CSI-2 interface with configurable 4-lane high-performance mode. Delivers maximum bandwidth for high-resolution sensor data transmission while maintaining compatibility with mainstream embedded platforms.
  • 8MP HD Camera: Designed for NVIDIA Jetson Orin Series, based on Sony 8MP IMX219 Sensor.
  • Higher quality: Compared with the official Raspberry Pi Camera v1, not only the resolution is improved, but its image quality, color fidelity, and low light performance are all upgraded by leap.
  • Wide Application: Perfect for time-lapse, slow motion, home security applications, monitoring Octoprint 3D Printer, and wildlife camera trap applications.
  • User-Friendly Setup: Requires only straightforward driver installation, making the setup process hassle-free and convenient for both beginners and experienced users alike.
Sensor IMX219
Still Resolution 8 Megapixels
Optical Size 1/4"
Sensor Output Format RAW
Platform Output Format YUV
Pixel Size 1.12 µm x 1.12 µm
Sensor Image Area 3.68 x 2.76 mm (4.6 mm diagonal)
Frame Rate 3280x2464@21fps, 3280x1848@28fps;
1920x1080@30fps, 1640x1232@30fps;
1280x720@60fps
Lens Specs
FOV 160°(D) x 110°(H) x 95°(V)
Lens Mount M12
F.NO F2.0
E.F.L 2.05±5%mm
Default Focus Range 0.8m to infinity
Weight 5g
Supported Platform NVIDIA Orin Nano/Orin NX/AGX Orin*
Supported JetPack Version JetPack6.2/L4T36.4.3 and later versions
Camera Interface MIPI CSI-2
MIPI Lanes 2-Lane/4-Lane
User Control Parameters (v4l2-ctl) Brightness, Contrast, Saturation, Hue, Sharpness, Flicker, hflip, vflip
Operating Voltage 3.3V
Power Requirements(Kit) 0.5W
Camera Board Size 25x24 mm
Overall Weight (Net) 15g
Temperature Range(Operating) -4°F-167°F (-20°C to +75°C)
Temperature Range(Stable Image) 32°F-122°F (0°C to +50°C)
Certification RoHS
  • 1 x Arducam 8MP IMX219 Wide Angle Camera Module for NVIDIA Jetson Orin Series
  • 1 x 22pin to 22pin FFC Cable (15cm)
  • If you intend to use this camera on the NVIDIA AGX Orin, you may need a CSI adapter board. You can contact Arducam for this accessory.
  • This camera is released for the official NVIDIA® Jetson™ Developer Kit, and it does not guarantee to support other third-party boards.
