Ribbon Cable Set (1.5″, 2.87″, 5.9″) for Raspberry Pi 0 and Zero 2W, Pack of 3
Arducam for Raspberry Pi Zero Camera Cable Set, 2 Pack 11.8
Arducam for Raspberry Pi Zero Camera Cable Set, 2 Pack 11.8" (30cm) Ribbon Flex Extension Cables for Pi Zero&W
Arducam for Raspberry Pi Zero Camera Cable, 3.8cm 15 pin to 22 Pin Camera Cable for Raspberry Pi Zero&W
CB008
Buy Now
  • You’ll Be Getting: 1 pcs 3.8cm flat camera cable, one end is 15 Pin 1.0mm Pitch interface and the other end is 22 Pin 0.5mm interface.
  • Compatibility: Natively compatible with Raspberry Pi zero&w, also can be used with Arducam MIPI camera series for raspberry pi.
  • Longer Than Others: Long enough for mounting the camera, especially useful when you don’t want to place the camera near the Raspberry Pi.
  • You Need It: Whatever for monitoring 3D printer, home security, or other raspberry pi camera project, this camera cable can meet your multi requirements.
  • Arducam is a company dedicated to open source hardware and software, specifically for Arduino and Raspberry Pi camera solutions. We also offer customized turnkey design and manufacturing solution services for customers who want their products to be unique.
$1.99
Arducam for Raspberry Pi Zero Camera Cable, 3.8cm Ribbon Flex Extension Cable for Pi Zero&W
    • 1pcs Pi Zero Camera Cable, 3.8cm Ribbon Flex Extension Cable for Pi Zero&W
