You’ll Be Getting: 1 pcs 11.81 inch (30cm) flat camera cable, one end is 15 Pin 1.0mm Pitch interface and the other end is 22 Pin 0.5mm interface.
Compatibility: Natively compatible with Raspberry Pi zero&w, also can be used with Arducam MIPI camera series for raspberry pi.
Longer Than Others: Long enough for mounting the camera, especially useful when you don’t want to place the camera near the Raspberry Pi.
You Need It: Whatever for monitoring 3D printer, home security, or other raspberry pi camera project, this camera cable can meet your multi requirements.
Arducam is a company dedicated to open source hardware and software, specifically for Arduino and Raspberry Pi camera solutions. We also offer customized turnkey design and manufacturing solution services for customers who want their products to be unique.
Arducam for Raspberry Pi Zero Camera Cable, 11.8" (30cm) Ribbon Flex Extension Cable for Pi Zero&W
1pcs Pi Zero Camera Cable, 11.8" (30cm) Ribbon Flex Extension Cable for Pi Zero&W
