Arducam Lens for Raspberry Pi HQ Camera, Wide Angle CS-Mount Lens, 6mm Focal Length with Manual Focus and Adjustable Aperture
Arducam CS-Mount Lens for Raspberry Pi HQ Camera, 8mm Focal Length with Manual Focus and Adjustable Aperture
LN038
It Just Works – We’ve tested this lens among the many other selected on the 12MP RPi HQ Camera. No lens shading, no dark corners, decent image quality, it just works.
The Wise Alternative – Another cost-effective choice that adds up to you Raspberry Pi High Quality Camera Module, with 8mm focal length and manual focus
Qualified Arducam – Arducam has been selecting and testing CS lenses on the Raspberry Pi cameras since the V1 camera era. Check B0032 if you want a 5MP Pi camera with CS Lens, and contact us to customized 8MP Pi cameras with CS lenses.
Other Specs – 50 degrees Horizontal Field of View (HFoV), 1/2.3″ Lens Optical Format, F/1.4, Dimension: Φ28×23mm, Weight: 40g
Search SKU UB0216 CB013 to get the tripod and camera cable for Raspberry Pi High Quality Camera
Specs
Model No: CS2308ZM05
Optical Format: 1/2.3"
Focal Length: 8mm
Aperture: F1.4
Field of View (FOV): 50°(H) on Raspberry Pi High Quality Camera, 30°(H) on Raspberry Pi V1/V2 Camera
Focus Type: manual
Mount: CS mount
Back Focal Length: 6.50mm
MOD: 0.3m
Dimension: Φ28×23mm
Weight: 40g
1pcs 1/2.3" CS-Mount 8mm Focal Length lens for Raspberry Pi
