Arducam 5MP OV5640 Camera Module for Toradex Apalis Arm and Verdin Arm Family
Arducam xISP - Darksee, Pre-tuned ISP, 8.3MP Low Light MIPI Camera for Ezurio SMARC® carrier board
Arducam 5MP OV5645 Camera Module for EZURIO SMARC
B0562
  • [Long-Proven Sensor] OmniVision 5MP sensor with 2592×1944 resolution.
  • [Ezurio SMARC SOM] Tailored for Ezurio SMARC carrier board.
  • [Wide Field of View] 88° diagonal field of view for extensive coverage.
  • [Streaming Excellence] 30fps at 1080p for clear video monitoring.
  • [On-chip ISP] Integrated ISP for enhanced image processing.
$24.99
The Arducam 5MP Camera Module is designed specifically for the Ezurio SMARC development kit, featuring a high-performance OmniVision sensor that delivers exceptional image quality. Perfectly compatible with Ezurio SMARC modules, a compact, powerful, and scalable module for IoT. With a wide 88° field of view and smooth 30fps streaming at 1080p, this module is ideal for IoT applications, ensuring reliable monitoring and advanced image processing through its integrated on-chip ISP.
  • IoT: Physical device interconnection and ubiquitous data perception.
  • Smart Surveillance: Real-time video monitoring for enhanced security.
  • Robotics: Vision systems for object detection and navigation.
  • Automated Inspection: Quality control and defect detection in manufacturing.
  • Smart Home Devices: Features like facial recognition and activity monitoring.
  • High-Performance Sensor: Utilizes a long-proven OmniVision 5MP sensor, achieving stunning still resolutions of 2592x1944.
  • IoT Application Focused: Specifically designed for Ezurio SMARC carrier board, optimizing performance for IoT applications.
  • Wide Field of View: Offers an impressive 88° diagonal field of view, ensuring comprehensive coverage for both low quantity and volume deployments.
  • Smooth Streaming: Delivers 30fps at 1080p, providing seamless video quality ideal for monitoring IoT applications.
  • Integrated On-Chip ISP: Features an integrated image signal processor (ISP) directly on the sensor for enhanced image processing capabilities.
Sensor OV5645
Still Resolution 5 Megapixel
Optical Size 1/4″
Output Format UYVY
Pixel Size 1.4 µm x 1.4 µm
Sensor Active Area 2592×1944 pixels
Frame Rate 2592x1944@16fps, 1920x1080@33fps, 1280x960@33fps;
FOV 88°(D)×74.3°(H)×58.4°(V)
Lens Mount Stock Lens
F.NO F2.0
E.F.L 2.46mm
Default Focus Range 0.69m-∞
Operating Temp. 0°C to 50°C
Power Consumption 3.3V / 300mA
Camera Board Size 25*24mm
Supported Platform Ezurio SMARC carrier board
  • 1 x Arducam 5MP Camera Module
  • 1 x 20cm 15pin-22pin FFC Camera Cable
  • Quick Start Guide
