Arducam 5MP AR0521 Color USB 3.0 Camera Module-Without Enclosure
Arducam 5MP AR0521 Monochrome USB 3.0 Camera Module-Without Enclosure
Arducam 5MP AR0521 Monochrome USB 3.0 Camera Module-With Enclosure
B0509C
  • Arducam AR0521 boasts a 5MP monochrome sensor for crisp detail at 2592×1944 resolution.
  • Flexible frame rates up to 1080p@60fps adapt to any capture scenario.
  • M12 lens with 95°(D) FOV, low distortion, and NIR responsivity ensure clarity in varied environments.
  • On-board ISP with proprietary tech guarantees top-tier image enhancement.
  • Plug-and-play compatibility with Windows and Linux, no additional drivers needed.
$154.99
Arducam's latest innovation in imaging technology, the AR0521 monochrome camera. Engineered as part of the Arducam USB 3.0 cameras series, this cutting-edge device boasts the prowess of the AR0521 sensor, a 5 MP powerhouse with a pixel size of 2.2 μm x 2.2 μm.
With an impressive Signal-to-Noise Ratio (SNR), this camera ensures minimal noise even in challenging conditions, while its near-infrared (NIR) responsiveness guarantees breathtaking image fidelity across diverse lighting scenarios. Thanks to the integration of a low-distortion lens, the AR0521 captures scenes with remarkable accuracy, offering users an authentic visual experience like never before.
  • Machine Vision
  • Video Surveillance
  • 3D Scanning and Metrology
  • Live Streaming
  • Video Conferencing
  • Crisp Clarity: With a high SNR 5MP monochrome AR0521 sensor, achieve a maximum still resolution of 2592x1944 for guaranteed clarity in every shot.
  • Flexible Capture: Enjoy flexible frame rates programmable up to 1080p@60fps. M12 lens with low distortion, manual focus, and a 95°(D) field of view ensures monitoring clarity.
  • Enhanced Performance: Low noise and near-infrared (NIR) responsivity expand imaging possibilities, delivering exceptional performance even in challenging lighting conditions.
  • Proprietary on-board ISP: de-Bayer, gamma, BLC, AE, AWB, CCM, RGB2YUV.
  • Plug and Play: Seamless compatibility with Windows and Linux, plug-and-play functionality eliminates the need for additional drivers.
Sensor AR0521
Still Resolution 5 Megapixels
Color Filter Type Mono
Optical Size 1/2.5"
Pixel Size 2.2× 2.2 μm
Sensor Active Area 2592 × 1944
Frame Rate (USB 3.0) 2592x1944@30fps, 1920x1080@60fps
Frame Rate (USB 2.0) 1920x1080@10fps
FOV 95°(D) × 81°(H) × 65°(V)
Lens Mount M12 (S-mount)
E.F.L 3.6mm
Default Focus Range 1m-∞
Power Requirements Max: 1.6W  , Min: 0.9W
  • 1 x AR0521 Mono USB3.0 Camera with Back Cover and Tripod Mount
