Arducam 20MP AR2020 Color USB 3.0 USB UVC Camera-Without Enclosure
Arducam 20MP AR2020 Monochrome Manual Focus USB 3.0 Camera-Without Enclosure
Arducam 20MP AR2020 Monochrome Manual Focus USB 3.0 Camera-With Enclosure
B0511C
  • Plug and play, no driver needed.
  • High-Res Imaging: AR2020 sensor, 20MP, exceptional clarity.
  • Versatile Frame Rate: Flexible rates up to 5120×3840 @8fps, 1280×960 @90fps.
  • Low-Light Performance and Enhanced NIR Response.
  • Proprietary on-board ISP advances image enhancement.
$264.99
Introducing the latest addition to Arducam's lineup: the AR2020 USB 3.0 camera. Boasting a 20MP 1/1.8" B/W CMOS sensor, this camera delivers stunning still images with a maximum resolution of 5120(H)*3840(V). Its exceptional low-light capabilities and near-infrared sensitivity make it perfect for a variety of night vision applications, including security surveillance, wildlife monitoring, iris recognition, and more.
Equipped with a high-quality 95-degree diagonal starlight M12 lens, this camera ensures crystal-clear imaging across diverse environments. Plus, it incorporates Arducam's advanced ISP technology, including de-bayer, gamma correction, black level compensation, auto exposure, color correction matrix, and RGB to YUV conversion. With a flexible and adjustable frame rate of up to 1280*960@90fps, it offers versatility to suit any project's needs.
  • Machine Vision
  • Security Surveillance
  • 3D Scanning and Metrology
  • Iris Recognition
  • Video Conferencing
  • High-Resolution Imaging: Utilizes a 1/1.8" AR2020 sensor, delivering stunning 20MP resolution, ensuring exceptional clarity in every capture.
  • Versatile Frame Rate: Offers flexible frame rates, supporting resolutions up to 5120 x 3840 @8fps for detailed imagery and 1280 x 960 @90fps for smooth motion capture, accommodating various application needs.
  • Proprietary on-board ISP advances image enhancement: de-Bayer, gamma, BLC, AE, CCM, RGB2YUV.
  • Exceptional Low-Light and NIR Performance: Features improved Near-Infrared (NIR) response at both 850nm and 940nm wavelengths, enabling enhanced night vision capabilities and increased sensitivity to infrared illumination.
  • Wide-Angle Lens: Equipped with a 95°(D) M12 Starlight Lens, capturing a broad field of view, perfect for surveillance, monitoring, and other wide-area applications.
Sensor AR2020
Still Resolution 20 Megapixels
Color Filter Type Mono
Optical Size 1/1.8"
Pixel Size 1.4× 1.4 μm
Sensor Active Area 5120(H) × 3840(V)
Frame Rate (USB 3.0) 5120x3840@8fps, 3840x2160@20fps, 2560x1920@30fps, 1920x1080@60fps, 1280x960@90fps
Frame Rate (USB 2.0) 1280x960@10fps
FOV 95°(D) × 82°(H) × 66°(V)
Lens Mount M12 (S-mount)
F.NO F1.65±10%
E.F.L 4.9±5%
Default Focus Range 3m-∞
Power Requirements Max: 1.57W  , Min: 0.8W
UVC Controls Brightness, Contrast, Gain, Exposure (Manual/Auto)
  • 1 x AR2020 Mono USB3 Camera with Back Cover and Tripod Mount
