Arducam 12MP IMX477P Mini High Quality Camera Module for ROCK 5A, 5B
Arducam 16MP IMX519 Camera Module for Rock 5A, 5B
B0518
  • 16MP IMX519 CMOS sensor ensures sharp, clear images and videos.
  • Captures stills at 4656×3496; supports 1080p60, 4656×3496 at 9fps, and 3840×2160 at 20fps.
  • Compact 24x25mm design for versatile integration into projects.
  • Seamlessly integrates with Rock 5A and 5B devices.
  • Easy setup with simple driver installation for all users.
$24.99
The Arducam IMX519 camera module is a high-quality imaging solution designed for advanced applications. Featuring a 1/2.53" 16MP CMOS, this module offers superior image quality and high resolution, making it an excellent choice for projects requiring detailed and vibrant visuals.
The advanced imaging capabilities are further enhanced by an 80° diagonal field of view (DFoV), ensuring that every shot is crisp and clear. One of the standout features of the Arducam IMX519 is its compact design. Measuring just 24x25mm, the mini camera board is highly versatile and can be seamlessly integrated into various projects.
Designed specifically for Rock 5A and 5B, the Arducam IMX519 camera module offers wide compatibility and seamless integration. Arducam has provided the necessary driver, requiring only a simple installation process to get started. This user-friendly setup makes it easy even for those with minimal technical expertise to install and use the camera efficiently.
  • Wildlife Photograph
  • Machine Learning
  • Home Security System
  • AI applications
  • DSLR Camera Control
  • High-Resolution Camera: Utilizes the IMX519 CMOS sensor with a 16MP capacity, ensuring exceptional sharpness and clarity for both images and videos.
  • Crisp Imaging: Delivers stunning still images at a maximum resolution of 4656*3496 pixels and supports various frame rates, including 1080p60, 4656x3496 at 9fps, and 3840x2160 at 20fps, providing flexibility for different recording needs.
  • Compact Design: Featuring a mini camera board size of 24x25mm, this module offers a compact form factor that seamlessly integrates into various projects, providing versatility without compromising on quality.
  • Tailored Compatibility: Specifically designed for Rock 5A and 5B, the IMX519 camera module ensures effortless integration with these devices, allowing users to fully utilize its capabilities without compatibility issues.
  • User-Friendly Setup: Requires only straightforward driver installation, making the setup process hassle-free and convenient for both beginners and experienced users alike.
Image Sensor IMX519
Still Resolution 16 MP
Shutter Type Rolling shutter
Optical Size 1/2.53"
Output Format 2LANE RAW10
Pixel Size 1.22 µm x 1.22 µm
Sensor Active Area 4656(H)×3496(V)
Sensor Frame Rate 4656x3496@9fps, 3840x2160@20fps, 1920x1080@60fps
Lens Mount Stock Lens
Focus Type Motorized Focus
FOV 80°(D)×67°(H)×53°(V)
F.NO F1.75
E.F.L 4.28mm
Default Focus Range 10cm-∞
Operating Voltage 3.3V
Power Requirements Max: 300mA
Camera Board Size 25 × 24mm
Supported OS ROCK 5A: Build 18
ROCK 5B: Build 39
Supported Platform Rock 5A, 5B
  • 1× IMX519 Camera Module for Rockpi
  • 1× 15cm 0.3mm 31Pin-0.5mm 22Pin FPC
  • The product does not come with any Rockpi motherboards included.
  • This camera module needs to be configured in advance on the Rock. The camera focus can be adjusted via software. For detailed instructions, see the Quick Start Guide provided below.
