Arducam 12MP IMX708 Wide Angle Camera Module for NVIDIA Jetson Orin NX, Orin Nano
B0482
  • Based on a 1/2.43-inch 12-megapixel IMX708 CMOS for sharp images
  • Maximum still resolution: 4608(H)×32592(V)
  • Mini size: same size (25*24mm) and mounting holes as Raspberry Pi Camera Module 3
  • With a 150°(D) M12 lens, captures a wider field of view and UHD images.
$39.99
This camera is a member of Arducam's V3 series of camera modules designed for Nvidia Jetson. The camera utilizes a Sony 11.9MP IMX708 image sensor for shooting Full HD videos and stills. It supports NVIDIA Orin NX/AGX Orin, Orin Nano on specific JetPack Version.
The camera comes with a 150°(D) wide-angle M12 lens. Wide-angle lenses always have a deeper depth of field and can effectively reduce bokeh. The manual focus camera allows you to use it for macro shots, low light, and other situations where autofocus is difficult to achieve.
  • Wildlife Photograph
  • Machine Learning
  • Home Security System
  • AI applications
  • DSLR Camera Control
  • HQ Camera: Capture sharp images with a 1/2.43-inch 12MP IMX708 CMOS, ensuring exceptional image quality.
  • Mini size: Compact and convenient, this camera is the same size as Raspberry Pi V3, making it easy to integrate into your projects.
  • Wide angle lens: Capture a wider field of view with the M12 lens and a 150°(D) FOV, delivering UHD images with an immersive perspective.
  • Broad compatibility: Specially designed for NVIDIA Jetson Platform. Support NVIDIA Orin NX/AGX Orin, Orin Nano on specific JetPack Version.
  • Please Note: An additional 15-22 pin FFC is included in the parcel that is required for use on Orin Nano and Orin NX. If you are using on AGX Orin, an additional camera adapter is required.
Image Sensor IMX708
Still Resolution 11.9 Megapixels
Video Modes 4608 x 2592@14fps, 2304 x 1296@55fps, 1536 x 864@90fps
Sensor Resolution 4608 x 2592 pixels
Sensor image area 6.45 x 3.63mm (7.4mm diagonal)
Pixel Size 1.4μm × 1.4μm
Optical Size 1/2.43"
Focal Length 2.87mm
Field of View(FOV) 150°(D)x120°(H)x66°(V)
Lens Mount M12
Power Requirements 3.3V, 300mA
Camera Board Size 25×24 mm
  • 1 x 12MP IMX708 Camera Module
  • 1 x 150mm 15pin-22pin FPC Cable
  • 1 x 150mm 15pin-15pin FPC Cable
