This 477 USB 3.0 camera boasts a maximum resolution of 12.3 megapixels utilizing the advanced 477 image sensor. With a maximum still resolution of 4056*3040, users can capture incredibly detailed images. Moreover, the camera's frame rate can reach up to 120fps@720P, ensuring smooth and fluid video capture.
With its high quality M12 Lens offering a field of view 88°(D), this camera captures stunningly accurate images.
| Image Sensor | |
| Sensor | 477 |
| Still Resolution | 12.3 Megapixels |
| Color Filter Type | Color |
| Shutter Type | Rolling |
| Optical Size | 1/2.3" |
| Output Format | YUY2 |
| Pixel Size | 1.55 µm x 1.55 µm |
| Sensor Active Area | 4056(H)×3040(V) |
| Frame Rate (USB 3.0) | 4056*3040@10fps, 3840*2160@20fps, 2016*1520@50fps, 1920*1080@60fps, 1280*720@120fps |
| Frame Rate (USB 2.0) | 1280*720@10fps |
| Lens | |
| Focus Type | Manual Focus |
| FOV | 88°(D)×75°(H)×60°(V) |
| Lens Mount | M12 Mount |
| F.NO | F2.8 |
| E.F.L | 3.9mm |
| Default Focus Range | 2.3m-∞ |
| USB Interface | |
| Power Requirements | Max: 1.31W , Min: 0.74W |
| UVC Controls | Brightness, Contrast, Saturation, Gain, White Balance (Manual and Auto) |
