Arducam 12.3MP IMX577 Mini Size High Resolution Camera Module for DepthAI(DM1090FFC)
B0597
  • [12.3MP High-Resolution Sensor] Captures detailed, clear images for vision applications.
  • Compact Mini Design - Easy to integrate into space-constrained devices.
  • Wide-Angle Lens - Fixed lens with low distortion for broad scene coverage.
  • DepthAI-Ready - Optimized for DepthAI(DM1090FFC )
  • Flexible MIPI Interface – Supports 2-lane and 4-lane MIPI (default 2-lane).
$59.99
The Arducam 12.3MP IMX577 Mini Camera Module is a high-resolution imaging solution tailored for DepthAI(DM1090FFC). Using the Sony IMX577 sensor, it delivers crisp, detailed images with a low-distortion wide-angle lens for expansive scene capture. Its compact form factor allows easy integration into drones, robots, and embedded systems. Supporting both 2-lane and 4-lane MIPI interfaces (default 2-lane), the module offers flexible deployment options for AI, machine vision, and edge computing applications.
  •  Robotics & Drones
  • Industrial Automation
  • AI & Computer Vision Projects
  • Smart Devices & Embedded Systems
  • Research & Prototyping
  • Surveillance & Monitoring
  • High-Resolution Imaging – Sony IMX577 sensor provides up to 12.3MP for sharp, high-quality images, enabling precise object detection and advanced computer vision tasks.
  • Low-Distortion Wide-Angle Lens – Fixed lens with a broad diagonal field of view reduces edge distortion while capturing expansive scenes.
  • Compact Mini Form Factor – Small and lightweight, making it ideal for space-limited applications such as embedded devices, drones, and robotic systems.
  • Optimized for DepthAI – Fully compatible with DepthAI(DM1090FFC), ensuring stable performance and seamless integration for robotics and AI projects.
  • Flexible MIPI Interface – Supports both 2-lane (default) and 4-lane MIPI, allowing users to choose the optimal data bandwidth for their application needs.
Sensor IMX577
Max Still Resolution 12.3 Megapixels
Optical Size 1/2.3″
Output Format RAW
Pixel Size 1.55 µm x 1.55 µm
Sensor Active Area 4056(H) x 3040(V)
Resolution&Frame Rate 4056x3040@15fps, 1920x1080@30fps;
FOV 88°(D)×75°(H)×47°(V)
Lens Mount M12
E.F.L 3.9mm
Default Focus Range 80cm~INF
Weight 5g
Power Consumption Max: 1.8W
Camera Board Size 24mm x 25mm
Overall Weight (Net) 10g
Exposure Time Range 10~50ms
Camera Interface MIPI CSI-2
Data Transmission Lanes 4-Lane
Supported Platforms DepthAI(OAK)
Temperature Range (Storage) -14°F-167°F (-10°C to +75°C)
Temperature Range (Operating) 32°F-122°F (0°C to +50°C)
Certification RoHS
  • 1 x Arducam 12.3MP IMX577 MIPI Camera Module
  • 1 x 15cm FPC Cable for DepthAI OAK
.tg {border-collapse:collapse;border-color:#aaa;border-spacing:0;} .tg td{background-color:#fff;border-color:#aaa;border-style:solid;border-width:1px;color:#333; font-family:Arial, sans-serif;font-size:14px;overflow:hidden;padding:10px 5px;word-break:normal;} .tg th{background-color:#f38630;border-color:#aaa;border-style:solid;border-width:1px;color:#fff; font-family:Arial, sans-serif;font-size:14px;font-weight:normal;overflow:hidden;padding:10px 5px;word-break:normal;} .tg .tg-uhrw{background-color:#FFF;border-color:inherit;color:#282828;text-align:center;vertical-align:middle} .tg .tg-75ta{background-color:#c0c0c0;border-color:inherit;color:#ffffff;text-align:center;vertical-align:middle} .tg .tg-maf8{background-color:#656565;border-color:#000000;color:#ffffff;text-align:center;vertical-align:middle} .tg .tg-ejxr{background-color:#ACB9CA;border-color:inherit;color:#ffffff;font-weight:bold;text-align:center;vertical-align:middle} .tg .tg-68t2{background-color:#E8E6E7;border-color:inherit;color:rgba(0, 0, 0, 0.87);text-align:center;vertical-align:middle} .tg .tg-avmv{background-color:#E8E6E7;border-color:inherit;color:rgba(0, 0, 0, 0.87);font-weight:bold;text-align:center; vertical-align:middle} .tg .tg-ef6b{background-color:#E8E6E7;color:rgba(0, 0, 0, 0.87);text-align:center;vertical-align:middle} .tg .tg-usqz{background-color:#ACB9CA;color:#ffffff;text-align:center;vertical-align:middle} .tg .tg-r40w{background-color:#cd9934;color:#ffffff;text-align:center;vertical-align:middle} .tg { width: 100%; } @media (min-width: 768px) { .tg { width: 60%; } }
