8MP A179 Autofocus USB2 UVC Camera Module with Metal Case, HDR-enabled Module Available
2MP IMX291 Low Light 120° Wide Angle USB Camera Module with Waterproof Metal Case  for Windows, Linux, Android, and Mac OS
8MP UVC Camera Module with Wide Angle M12 Lens for Windows, Linux, Android, and Mac OS
B0446
  • [Plug-and-Play] UVC-compliant, No additional driver is needed.
  • [Ultra HD] Based on performance 8MP color image sensor
  • [Wide-Angle] Armed with a wide angle low distortion M12 Lens
  • [Onboard ISP] Integrated hardware ISP. Support auto exposure, auto white balance, etc.
  • [Upgraded item available now] Select B044601 with HDR and AI Resolution enhanced.
As low as $54.99
It is a fully UVC-compliant plug-and-play solution with a robust metal housing that works seamlessly on Windows, Linux, Android, and macOS with no driver installation required. Built on a high-performance 8MP color image sensor, it delivers sharp Ultra HD visuals suitable for a wide range of vision applications. The module comes equipped with a wide-angle, low-distortion M12 lens for accurate and extended scene coverage, while the onboard hardware ISP ensures consistent image quality with auto exposure, auto white balance, and other essential controls handled directly on the device. An upgraded version B044601 is also available, featuring enhanced HDR imaging and AI-optimized resolutions for more demanding computer-vision workflows.
  • Live streaming
  • Video conference
  • Monitoring 3D printer
  • Dashcam
  • Plug-and-Play UVC Compatibility:
    It is fully UVC-compliant, enabling seamless plug-and-play operation on Windows, Linux, Android, and macOS without any driver installation. It integrates easily into existing systems for rapid deployment.
  • Low-Distortion Wide-Angle M12 Lens:
    The integrated M12 lens offers an wide horizontal field of view with low optical distortion, ensuring accurate scene capture for robotics, smart terminals, people detection, and other spatial-awareness applications.
  • Onboard Hardware ISP:
    Featuring a built-in image signal processor, the camera delivers consistent, high-quality output with hardware-level enhancements.
  • Upgraded Variant with HDR and AI Resolutions:
    A new enhanced version of the module - B044601 is available for selection, adding High Dynamic Range (HDR) for superior performance in challenging lighting and AI-optimized YUV resolutions for edge inference.
General Sepcs B044601 B0446-1
Still Resolution 8MP 8MP
Color Filter Type Color Color
Shutter Type Rolling Rolling
Optical Size 1/2.8'' 1/3.2"
Pixel Size 1.6 µm x 1.6 µm 1.4 µm x 1.4 µm
Sensor Active Area 3264(H)x2448(V) 3264(H)x2448(V)
Frame Rate MJPG: 3264x2448@25fps, 2592x1944@25fps;
1920x1080@30fps, 1600x1200@30fps;
1280x720@30fps, 640x480@30fps;
MJPG: 3264×2448@30fps, 2592x1944@30fps;
YUY2: 3264×2448@1fps, 2592x1944@2fps;
1920x1080@5fps, 1600x1200@5fps;
1280x720@10fps, 640x480@30fps;
320x320@30fps, 128x128@30fps;
96x96@30fps;
Focus Type Fixed Focus Fixed Focus
FOV 101°(D)×85°(H)×65°(V) 130°(D)x115°(H)x90°(V)
Lens Mount M12-S M12-S
F.NO F2.7±5% F2.1±5%
E.F.L 2.7mm 2.1mm
Default Focus Range 300cm-∞ 300cm-∞
Distortion <-1.0% <20%
Operating Voltage DC 5V +/- 5% DC 5V +/- 5%
Power Consumption 1.1W 0.8W
Camera Board Size 32mm x 32mm x 1.6mm 38mm x 38mm x 1.6mm
HDR Support Yes NO
Supported OS Windows, Linux, Android Windows, Linux, Android
UVC Controls Brightness, Contrast, Saturation, White Balance (Auto/Manual), Gain, Lowlight Compensation, Focus (Auto/Manual), Exposure (Manual/Auto) Brightness, Contrast, Hue, Saturation, Sharpness, Gamma, White Balance, Backlight Comp, Gain
  • 1 x Arducam 8MP Wide Angle USB Camera Module
  • 1 x USB Cable (1m)
  • 1 x Quick start guide
