USB2.0 UVC Camera Module, 2.3MP Global Shutter, with Onboard ISP for Robotics & Machine Vision
8MP HDR USB Autofocus Camera Module with Metal Housing for Windows, Linux, Android, and Mac OS , A179
8MP Autofocus USB Camera Module with Single Microphone for Windows, Linux, Android, and Mac OS , A179
B0447-1
  • [High Resolution] 8MP HD, Max resolution: 3264*2448
  • [Autofocus] Armed with a 63° (HFOV) Autofocus Lens.
  • [Frame Rate] MJPG 30fps@3264 x 2448, 30fps@1080P; YUY2 30fps@640x 480.
  • [Rich Applications] Can be applied in surveillance systems, 3D Printing, security systems, and so on.
arducam shipping payment 1
$58.99
8MP USB camera module with built-in autofocus and a single microphone, offering high-resolution imaging (up to 3264×2448) across Windows, Linux, Android, and macOS. With plug-and-play support and no driver required, it delivers smooth video performance at 30fps in both HD and Full HD. Its 63° HFOV autofocus lens ensures sharp focus, making it ideal for applications such as surveillance, 3D printing, and security systems.
  • Robotics
  • Precision Agriculture
  • [Plug-and-Play] Fully UVC-compliant and driver-free, this camera module supports instant plug-and-play functionality across Windows, Linux, Android, and macOS platforms. Simply connect via USB and start capturing without the need for additional software or configuration.
  • [High Resolution] Equipped with an 8MP sensor, the camera delivers high-definition images with a maximum still resolution of 3264×2448, making it ideal for applications that require clear, detailed visuals.
  • [Autofocus] Featuring a built-in 63° horizontal field of view (HFOV) autofocus lens, the module automatically adjusts focus to ensure sharp and accurate imaging, even when object distances change—perfect for dynamic or multi-distance environments.
  • [Frame Rate] Supports smooth video streaming with MJPG compression at up to 30fps for both full 8MP (3264×2448) and 1080P resolutions. Also supports YUY2 format at 30fps for lower resolutions like 640×480, providing flexible options for various bandwidth and performance needs.
  • [Rich Applications] Designed for versatility, this camera module is well-suited for a wide range of use cases including surveillance systems, 3D printing monitoring, security integration, machine vision, and other embedded vision projects.
General Sepcs B044701 B0447-1
Still Resolution 8MP 8MP
Color Filter Type Color Color
Shutter Type Rolling Rolling
Optical Size 1/3.2'' 1/3.2"
Output Format MJPG/YUY2 MJPG/YUYV
Pixel Size 1.4 µm x 1.4 µm 1.4um x 1.4um
Sensor Active Area 3264(H)x2448(V) 3264(H)x2448(V)
640x480@30fps;
3264×2448@30fps, 2592×1944@30fps;
1920×1080@30fps, 1600×1200@30fps;
1280×720, 640×480@30fps;
320x320@30fps, 128x128@30fps;
96x96@30fps;
1280×720@10fps, 640×480@30fps;
FOV 75°(D)×61°(H)×50°(V) 63°(H)
F.NO F1.8 F2.0
E.F.L 3.95mm 3.54mm
Operating Voltage 5V 5V
Power Consumption 1.75W 1.5W
HDR Support Yes NO
Supported OS Windows, Linux Windows, Linux
UVC Controls Brightness, Contrast, Saturation, White Balance (Auto/Manual), Gain, Lowlight Compensation, Focus (Auto/Manual), Exposure (Manual/Auto) Brightness, Contrast, Saturation, White Balance (Auto/Manual), Gain, Focus (Auto/Manual), Exposure (Manual/Auto)
  • 1 x Arducam 8MP AF Camera Module
  • 1 x USB Cable (1m)
  • 1 x Quick start guide
