Raspberry Pi Official Camera Module V3-12MP IMX708 102° Wide Angle Autofocus Camera with Acrylic Case
Multi Camera Adapter Module V2.2 for Rasperry Pi Camera Module 3 12MP IMX708 / 5MP OV5647 / 8MP IMX219 / 12MP IMX477 Cameras
200mm Sensor Extension Cable for Raspberry Pi Camera Module V2/V3, Support Working on Raspberry Pi and Jetson Board
B0439
  • Developed for V3: Specially designed and made for Raspberry Pi V3 camera
  • Easy to SetUp: Just need to detach the connectors and re-attach it with the cable
  • Space Saving: 9mm width and 0.1mm thickness. A powerful assistant for your narrow space projects
  • Compatiblity: Raspberry Pi V2/V3; Part of Arducam IMX219 Cameras
  • Multi Platform: Support working with V2/V3 on Raspberry Pi and IMX219 on Nvidia Jetson
arducam shipping payment 1
$11.99
After the release of the Raspberry Pi V2 camera, we designed a unique camera extension cable (B0186) to meet the requirement for camera extension. The extension cable can extend the working distance of the camera and ensure signal transmission.
With the release of the latest Raspberry Pi V3 camera module, we specially made this Sensor Extension Cable adapt to the V3 extension solution.
You just need to remove the connector and reconnect the camera board and the connector with an extension cable. There is no need to install an additional driver.
Meanwhile, this cable is not only compatible with Raspberry Pi V2/V3 cameras but can work directly with Arducam IMX219 cameras. As for platform compatibility, you can also use this cable with IMX219 Camera on Nvidia Jetson Board.
  • Designed for V3: A fresh Arducam design to extend your camera vision on the latest released Raspberry Pi Camera Module V3
  • Easy to SetUp: Just need to peel off the sensor from the connector on the camera board and put our cable in between. No additional Driver is needed
  • Support V2/V3 and More: Not only work with Raspberry Pi V2/V3 camera. Also compatible with Arducam IMX219 Drop in Replacement cameras
  • Flexible Vision: The flexible and narrow cable body allows you to place it in narrow places such as enclosures and holes, saving you space while completing your projects
  • Wide Compatibility: Support working with IMX219 and IMX708 image sensors. Compatible with Raspberry Pi and NVIDIA Jetson platforms.
Supported Sensor IMX219/IMX708
Cable Length 200mm
Cable Width 9mm
Cable Thickness 0.1mm
Electromagnetic shielding With Electromagnetic shielding
Supported Platform Raspberry Pi/Nvidia Jetson
  • 1 x  Arducam 200mm extension cable for Raspberry Pi and Nvidia Jetson Camera Module
  • The Raspberry Pi Camera Module V2/V3 is NOT included in the package.
  • The cable is mainly designed for V2/V3 Camera Module. It does NOT support 5MP V1 cameras or any other sensors.
  • Please detach and re-attach the connectors gently and carefully, otherwise you might cause damage to the connection.
  • Please Note that a camera board is needed to work with this extension cable
  • This cable is released for the official NVIDIA® Jetson™ Developer Kit, and it does not guarantee to support other third-party boards.
Supported Cameras
Picture v3 B0207 B0180 B0181 B0182 B0183 B0184 B0390 v3 v3 v3 v3 v3
SKU V3 V2 B0180 B0181 B0182 B0183 B0184 B0390 B039001 B0392 B0393 B0394 B0395
Sesnor IMX708 IMX219 IMX219 IMX219 IMX219 IMX219 IMX219 IMX219 IMX219 IMX219 IMX219 IMX219 IMX219
Resolution 12MP 8MP 8MP 8MP 8MP 8MP 8MP 8MP 8MP 8MP 8MP 8MP 8MP
Focus Type Autofocus Fixed Focus Manual Focus Autofocus Autofocus Manual Focus Manual Focus Fixed Focus Fixed Focus Manual Focus Autofocus Manual Focus Fixed Focus
