[Discontinued] 1/3” AR0331 USB Camera with 4mm Manual Focus CCTV Video Lens, 3MP HDR UVC USB2.0 Webcam with Dual Microphones, Mini Tripod, and 6.56ft/2m Cable for Computer-Arducam
[Discontinued] OpenCV AI Kit OAK-1: IMX378+Intel Movidius Myriad X for Depth AI OAK
[Discontinued] 2.8-12mm Varifocal Lens Web Camera with 1/2.7" AR0230 Image Sensor, 1080P HDR USB Camera with CCTV Video Lens for Android, Linux, Windows-Arducam
B0357
Discontinued, check alternative item B0438.
$62.99
The B0357 is a new member of Arducam’s USB camera family. It’s a 2MP, UVC compliant, USB 2.0 camera. This USB camera is based on the 1/2.7” AR0230 image sensor and has the ability to stream images and videos seamlessly. All Auto functions can be performed (Auto White Balance, Auto Exposure control). Standard UVC protocol, compatible with Windows 7/8/10, Mac OS, Andriod, and Linux.
It is assembled with a CCTV camera varifocal lens that allows you to adjust the focal length for your specific needs. Adjust the focus and focal length by simple zoom and manual focus, this webcam is easy to deliver crisp images with good color saturation and purity.
【HD 1080P Webcam】High-quality USB camera adopted CMOS AR0230 image sensor with max resolution 1920x1080 for great picture performance, keep the purity and clarity of images. High frame rate: 1080P@30fps, Compression format: MJPG / YUY2; Saturation, Contrast, White balance adjustable.
【2.8-12mm CCTV Video Lens】2.8-12mm varifocal lens USB camera with IR-cut filter@650nm provides a field of view from 55°-38° different angles. The focal length is 2.8-12mm and the minimum focusing distance is 10mm, which could capture every tiny detail to meet the needs of different scenes.
【HDR & WDR】Up to 96dB wide dynamic range, this webcam supply crisp image and crystal clear video at a fluid 30 frames.
【Plug & Play】UVC-compliant, just connect the camera to a PC computer, laptop, or Raspberry Pi with the USB cable without extra drivers to be installed.
【Applications】Highly recommended for the video surveillance system, live streaming, video conference, dashcam, and other video vision applications need high frame rates with high resolution.
Sensor: 1/2.7” AR0230
Resolution: 1928(H) x 1088(V)
Data Format: MJPG/YUY2
Frame Rate: MJPG 30fps@1080P/720P/1280 x 1024/800 x 600/640 x 480; YUY2 5fps@1080P/720P; 20fps@800 x 600/960 x 540; 30fps@640 x 480
Focal Length: 2.8-12mm
Field of View (FOV): 75°-35°
Lens Mount: M12
IR Sensitivity: Integral IR filter, visible light only
Auto Controlled Features: Saturation, Contrast, Acutance, White balance, Exposure.
System Compatibility: Windows, Linux, Android and Mac with UVC
Power
Power Supply: USB powered 5V
Working Current: MAX 300mA
Physical
Operating Temp.: -4°F~158°F (-20°C~+70°C)
Dimension: 38mmx38mmx50mm
Cable Length: default 3.3ft (1M)
Manual.pdf
Manual.pdf
