[Discontinued] Arducam OV9281 1MP Mono Global Shutter Camera with 130deg 850nm Only M12 Mount for Raspberry Pi
[Discontinued] Arducam 13MP MIPI Camera Module with AR1335 OBISP and Motorized IR-CUT Filter for Daylight and Night vision Support Raspberry Pi, Jetson Nano (Jetvariety ISP 13 SIF)
[Discontinued] Arducam 16MP IMX298 USB Camera w/ M12 lens
B0246
Discontinued, check alternative item B0268.
$69.99
  • Sensor: 16MP 1/2.8” IMX298
  • Resolution: 16MP 4656H x 3496V
  • Data Format: MJPG/YUY2
  • Field of View (FOV):H=70° M12 lens
  • IR Sensitivity:Integral IR filter, visible light only
  • Frame Rate: MJPG 10fps@4656x3496/3264x2448/2592x1944/, 30fps@1080P/720P/1024x768;
    YUY2 8fps@1024x768, 10fps@640x768
  • Power Supply: DC 5V
  • Working Current: MAX 200mA
  • Dimension: 38mmx38mm
  • Cable length:3.3ft/1m
  • Win7/8/10, Linux, Mac and Android with UVC
Documentation:
User guide.pdf
  • 1pcs Arducam IMX298 USB2.0 Camera Module
  • 1pcs 3.3ft (100cm) USB cable
windows usb camera module blog thumbnail
The Different Kinds of Camera Modules You Can Use with Windows PCs
Cameras on the Windows Platform If you click the start menu on Windows 10, you will probably find an app called “Camera.” On a laptop, the app shows the built-in front-facing camera with some simple controls, but how would you use a camera on the desktop end? Aside from a built-in webcam, there are several […]
