[Discontinued]12.3MP 477P Camera Module with M12 Lens for Raspberry Pi
12.3MP 477M HQ Camera Module for Raspberry Pi with 158°(D) M12 Wide Angle Lens
B0466R
  • Based on a 1/2.3-inch 12-megapixel CMOS for sharp images
  • Maximum still resolution: 4056(H)×3040(V)
  • Video modes: 2028 × 1080p50, 2028 × 1520p40 and 1332 × 990p120
  • Mini size: same size (25*24mm) and mounting holes as Raspberry Pi V2
  • With an interchangeable 158°(D) M12 lens, captures a wider field of view and UHD images.
$49.99
Experience exceptional image quality with the Arducam mini-sized Camera Module for Raspberry Pi. This camera module supports various video modes, including 2028 × 1080p50, 2028 × 1520p40, and 1332 × 990p120. The rolling shutter and color filter array enhance performance, delivering accurate and vibrant colors.
With manual focus and a focal length of 2.87mm, achieve precise focusing for your shots. The M12*P0.5mm lens offers a wide field of view (DFOV / HFOV / VFOV: 158°/120°/105°), capturing expansive scenes.
Despite its compact 25 × 24mm board size, the Raspberry Pi MIPI Camera packs a powerful imaging punch. Elevate your photography and videography capabilities with this versatile camera module, perfect for Raspberry Pi projects and capturing the world around you.
  • Astrophotography
  • Surveillance cameras
  • FA cameras
  • High Quality Camera: Capture sharp images with a 1/2.3-inch 12MP CMOS, ensuring exceptional image quality.
  • More than HD: Max still resolution: 4056 x 3040. Enjoy stunning visuals with a maximum static resolution of 4056 x 3040 and various frame rates for smooth video recording.
  • Mini size: Compact and convenient, this camera is the same size as Raspberry Pi V2, making it easy to integrate into your projects.
  • Wide angle lens: Capture a wider field of view with the interchangeable M12 lens and a 158°(D) FOV, delivering UHD images with an immersive perspective.
  • Broad Pi compatibility: Compatible with a wide range of Raspberry Pi models, including Raspberry Pi 1, 2, 3A/B, 4A/B, Zero, and Zero 2W, ensuring flexibility and versatility in your projects. No additional driver installation is required, and it supports libcamera commands.
Video Modes 2028 × 1080p50, 2028 × 1520p40 and 1332 × 990p120
Pixel Size 1.55 µm x 1.55 µm
Optical Size 1/2.3"
Focal Length 2.87mm
Field of View(FOV) 158°(D)×120°(H)×105°(V)
Lens Mount M12
Camera Board Size 25 × 24mm
  • 1 x 12MP 477M Camera Module
  • 1 x 15-22pin FPC Cable
  • 1 x 22-22pin FPC Cable
  • 1 x Paper Quick Start Guide
  • For Arducam 477M Camera, you need to refer to the following contents to access the camera: Quick Start Guide for 477M Camera
