[Discontinued] USB2 Camera Shield - Support both MIPI and Parallel Interface Sensors
[Discontinued] HM0360 VGA CMOS Monochrome Camera Module (NoIR) for RP2040 & Arduino-Arducam
[Discontinued] 1080P 60FPS HD USB Camera, H.265/H.264 High Definition 2MP UVC Camera for Industrial Webcam, High-Speed USB 2.0 Camera Without Microphone
UB0241
Discontinued, check alternative item B0200.
$45.99
Arducam 1080P 60FPS USB Camera
This is Arducam's latest HD 1080P USB camera, which uses the high quality 1080P CMOS image sensor GalaxyCore GC2093, which integrates a 1920H x 1080V pixel array with high performance and low power consumption features that enable you to integrate it into various sports cameras, car DVRs, digital cameras and other devices for various mobile applications.
Feature
  • 1080P 60FPS HD USB camera: This USB camera module adopts 1/2.9" high-quality and low power consumption 2MP CMOS, with resolution up to 1920*1080 and output frame rate up to 60fps, which can make the image effect vivid and more realistic.
  • H.264/H.265 Compression Format: 60fps UVC camera not only supports MJPG/YUYV encoding format, but also H.265/H.264 video encoding format; at the same picture quality, H.265 encoding format only occupies 50% of the bandwidth, which can make your live video more smooth (H.264/H.265 video capture requires the use of (Special software, PotPlayer is recommended).
  • HDR and Low Distortion: This 1080P webcam is equipped with a fixed focus lens, available focal length 2m - infinity, distortion: TV<1%, FOV 63°(H), transmitting the most realistic image effect.
  • Plug&Play: mini-sized, no driver required. The USB camera board is equipped with a 4pin to USB connector on the back for direct PC connection, compatible with the various platforms such as Linux, Windows, Andriod, and Mac OS; it also supports the use of Zoom/Skype/Facetime and other video streaming APP.
  • Applications: This tiny USB camera is suitable for any embedded applications that require image captures, such as intelligent identification systems, industrial Testing, Medical Live Streaming, Surveillance Cameras, smart homes, and video doorbells.
Sensor 1/2.9” GC2093
Resolution 2MP 1920H x 1080V
Pixel Size 2.8 µm x 2.8 µm
Data Format MJPG/YUYV/H.264/H.265
Frame Rate MJPG 60fps@1920×1080 /640×360/640×480/320×240/1280×720; YUYV 10fps@1280×720;5fps@1920×1080; 60fps@320×240;30fps@640×360/640×480; H.264/H.265 60fps@1920×1080/1280×720
Auto Controlled Features Contrast/ Saturation/ Exposure / White balance / Acutance
System Compatibility Win7/8/10, Linux, and Mac with UVC
Dimension 38x38x14mm
Connector No. 533980471
Cable Length 1.64ft (0.5M)
Field of View (FOV) 74.38°(D) ,63°(H)
Optical Length 7.81MM±0.3MM
TV Distortion <1%
Focal Length 4.35±5%
Lens Construction 4P+1R
IR Sensitivity Integral 650 IR filter, visible light only
F.NO 2.0±5%
Lens Mount M8+0.35P
h.265
