The Arducam T2 All-in-One Kit is the ultimate solution for developers and innovators seeking a ready-to-use RGBD ToF camera. With its 1% depth accuracy, VGA resolution, and up to 33fps frame rate, it delivers unmatched precision and performance. The kit includes everything you need to get started—camera module, processor board, cables, and accessories—making it perfect for prototyping, robotics, AR/VR, and more.
Robotics: For obstacle detection, navigation, and object recognition.
Augmented Reality (AR)/Virtual Reality (VR): For immersive, high-precision depth sensing.
3D Scanning: For creating detailed 3D models and reconstructions.
Smart Home: For gesture control, security monitoring, and automation.
Industrial Automation: For quality control, sorting, and precision measurements.
RGBD Imaging for Enhanced Data The Arducam T2 combines RGB (color) and depth sensing in a single device, providing richer, more detailed visual data. This dual capability is ideal for applications where both color and depth information are critical, such as AR/VR, robotics, and 3D scanning.
Unmatched Depth Accuracy With 1% depth accuracy, the T2 ensures precise measurements, even in complex environments. This level of precision is a significant improvement over the T1’s 3% accuracy, making it suitable for applications like industrial automation and medical devices
VGA Resolution The T2 supports up to VGA resolution (640×480), delivering clear, detailed depth maps. This is a major upgrade from the T1’s 240×180 resolution, providing more data for accurate analysis and decision-making.
Complete Kit for Immediate Use The All-in-One Kit includes the camera module, processor board, cables, and accessories, providing everything you need to start your project right away. It’s perfect for developers who want a plug-and-play solution without the hassle of sourcing components.
Single Frequency: 120MHz;Dual Frequency: 120MHz / 20MHz
Measurement Distance
3m@10% Reflectivity
Measurement Accuracy
1%@full range
Backend Platform
Raspberry Pi 5
Software OS
Bookworm(32bit/64bit)
Camera Board Size(LxW)
38mm x 38mm
Operating Temp.
-25°C to 60°C
Working Current(Camera Module)
MAX:3.3V/310mA MAX:5.0V/700mA
Power Supply Requirement
MAX: 27W
1 x Arducam PiVistation 5 RGBD Camera All-in-one Kit
Warning: Do not attempt to disassemble the device. The module is factory-calibrated, and any unauthorized disassembly will void the calibration. Arducam assumes no responsibility for any image quality issues caused by such actions.
Tripod is not included in the package, please check UB0224 and UB0216 for additional purchase.
