1.58MP IMX296 Mono Global Shutter Camera Module with M12 Lens for Raspberry Pi
B0619
  • [Global Shutter] Based on 1.58MP IMX296 Mono Global Shutter image sensor.
  • [Low Distortion Lens] Equipped with a 96°(dFOV) M12 Lens.
  • [Manual Focus] Especially suitable for special photographic conditions such as low light and macro, etc.
  • [Platforms] Supports Raspberry Pi 5, 3, 4 A/B, equipped with 15-22pin and 22-22pin FPC flexible cables.
  • [Cost-effective] Second-to-none choice for given image and cost. High Performance with low consumption.
$84.99
This camera is based on SONY IMX296 Mono Global Shutter image sensor. Global shutter technology allows you to reduce or eliminate unwanted image artifacts, which occur with traditional rolling shutter image sensors as a result of motion during image capture. The camera is equipped with a 96°(dFOV) M12 Lens. A manual focus M12 camera allows you to apply it in situations such as macro photographs, low light conditions, etc. Meanwhile, this camera is native to Raspberry Pi and fully supported by libcamera and Picamera2 library. Arducam is committed to creating diverse and convenient camera solutions for embedded camera users. We are not only engaged in the production and development of optical products, but also strive to provide complete solutions for Embedded cameras, Evaluation kit, Optical components, etc.
  • Home Security System
  • Wildlife Photography
  • Unattended surveillance
  • Industrial Vision/Machine Vision
  • Automation, AI Project, etc.
  • Global Shutter: Based on SONY IMX296 Mono Global Shutter Image Sensor. The sensor is a CMOS active pixel type solid-state image sensor with a square pixel array and 1.58 M effective pixels.
  • M12 Lens: Armed with a 96° (dFOV) M12 Lens with low distortion.
  • Manual Focus: Manual Focus cameras are always more suitable in some special conditions. For example, in low-light and macro photography environments, manual focus can obtain a complete overall contrast of pictures, thereby improving image quality and focus accuracy.
  • Raspberry Pi Native: Native to Raspberry Pi. No additional camera driver is needed.
  • Wide Compatibility: Compatible with Raspberry Pi 5, 3, 4 A/B, equipped with 15-22pin and 22-22pin FPC flexible cables. Support used on Raspberry Pi Zero.
Sensor IMX296
Resolution 1.58 Megapixels
Chroma Monochrome
Shutter Type Global Shutter
Optical Format 1/2.9"
Pixel Size 3.45 µm x3.45 µm
Sensor Active Area 1440(H)×1080(V)
Sensor Image Area 5.023 mm x 3.788 mm (6.3mm diagonal)
Output Format RAW10
Resolution@fps 1440x1080@60fps
FOV 96°(D)×89°(H)×58°(V)
E.F.L 2.8mm
IR Sensitivity NoIR, sensitive to IR Light
Default Focus Distance 50cm
DOF Range 26cm~INF
Distrotion <1.50%
Weight 4g
External Trigger Mode Support
Supported Platform Raspberry Pi
Supported OS Bullseye/Bookworm/Trixie
Camera Interface MIPI CSI-2
MIPI Lanes 1-Lane Driver
Operating Voltage 3.3V
Power Consumption 0.85W
Camera Board Size 38×38 mm
Overall Weight (Net) 14g
Certification RoHS
  • 1 x Arducam 1.58MP IMX296 Mono Global Shutter MIPI Camera Module
  • 1 x 15cm 22-22pin FFC Cable
  • 1 x 15cm 15-22pin FFC Cable
