1.58MP IMX296 Color Global Shutter Camera Module with M12 Lens for Raspberry Pi
B0445
  • Global Shutter: Based on 1.58MP IMX296 Color Global Shutter image sensor.
  • Replaceable M12 Lens: Equipped with a 45°(HFOV) M12 Lens. With 13mm Lens Holder.
  • Manual Focus: Especially suitable for special photographic conditions such as low light and macro, etc.
  • Supports Raspberry Pi 5, 3, 4 A/B, equipped with 15-22pin and 22-22pin FPC flexible cables.
  • Cost-effective: Second-to-none choice for given image and cost. High Performance with low consumption.
arducam shipping payment 1
$84.99
This camera is based on SONY IMX296 Color Global Shutter image sensor. Global shutter technology allows you to reduce or eliminate unwanted image artifacts, which occur with traditional rolling shutter image sensors as a result of motion during image capture.
The camera is equipped with a 55°(HFOV) M12 Lens. A manual focus M12 camera allows you to apply it in situations such as macro photographs, low light conditions, etc. Meanwhile, this camera is native to Raspberry Pi and fully supported by libcamera and Picamera2 library.
Arducam is committed to creating diverse and convenient camera solutions for embedded camera users. We are not only engaged in the production and development of optical products, but also strive to provide complete solutions for Embedded cameras, Evaluation kit, Optical components, etc.
  • Home Security System
  • Wildlife Photography
  • Unattended surveillance
  • Industrial Vision/Machine Vision
  • Automation, AI Project, etc.
  • Global Shutter: Based on SONY IMX296 Color Global Shutter Image Sensor. The sensor is a CMOS active pixel type solid-state image sensor with a square pixel array and 1.58 M effective pixels.
  • M12 Lens: Armed with a 45° (HFOV) M12 Lens. Integrated with a M12 Lens Mount, of which Length Holder Height is 13mm.
  • Manual Focus: Manual Focus cameras are always more suitable in some special conditions. For example, in low-light and macro photography environments, manual focus can obtain a complete overall contrast of pictures, thereby improving image quality and focus accuracy.
  • Raspberry Pi Native: Native to Raspberry Pi. No additional camera driver is needed.
  • Wide Compatibility: Compatible with Raspberry Pi 5, 3, 4 A/B, equipped with 15-22pin and 22-22pin FPC flexible cables. Support used on Raspberry Pi Zero.
Image Sensor IMx296
Resolution 1.58MP
Optical Size 1/2.9''(6.3mm sensor diagonal)
Number of effective pixels 1440(H) × 1080(V)
Pixel Size 3.45μm × 3.45μm
Support Platform Raspberry Pi 5/4/3/Zero/CM3/CM4
Shutter Type Global Shutter
Color Filter Array Quad-Bayer RGB
Frame Rate RAW10:1440x1080@60fps
Output Format RAW10
F.NO F2.0
Focal Length 6mm
Lens Size M12 Lens(M2506ZH04)
Field of View(FOV) 55°(D)x45°(H)x33°(V)
Camera Board Size 38 × 38mm
  • 1 x Arducam 1.58MP IMX296 Global Shutter camera module with M12 Lens
  • 1 x 150mm 15pin-22pin FPC Cable
  • 1 x 150mm 22pin-22pin FPC Cable
  • This camera is natively supported by Raspberry Pi, you don't need additional driver to run it, but you will need some configuration, please refer to the following doc.
    Raspberry Pi 5 √ √
