Product Description
OmniVision’s OV9782 is a 1MP (1280×800) global shutter color image sensor. Arducam OV9782 camera module is a color camera option for OAK Series 2 Wide FOV cameras such as OAK-D W, OAK-D W PoE as the 150° DFOV color camera.
It is also compatible with OAK FFC boards (OAK-FFC-3P, OAK-FFC-4P), so you can easily evaluate its sensor and optics performance via a camera board and a flex cable.
Specification
| Sensor | OV9782 |
| Optical Size | Type 1/4” |
| Pixel Size | 3μm×3μm |
| Shutter Type | Global Shutter |
| Color Filter Array | RGB |
| Max Sensor Resolution | 1280 x 800 |
| Resolution & Frame Rate | 1280×800@60fps, 1280×720@60fps, 640×400@120fps |
| Supported Platform | OAK-D W, OAK-D W PoE, OAK-FFC-3P, OAK-FFC-4P |
| Output | RAW8/RAW10 |
| Focus Type | Manual |
| Focus | 50cm~INF |
| Lens | f/2.0, EFL: 1.69mm, FoV: 150° (D) |
| IR Sensitivity | Built-in 650nm IR filter, sensitive to visible light only |
| Module Dimensions | 8.5mm x 14.67mm |
Documentations
Packing List
- 1 x OV9782 Wide Angle Camera Module for DepthAI OAK
