OV9282 Mono Global Shutter 1MP Wide Angle Camera Module for DepthAI OAK
  • Global shutter: Higher frame rates in extracting depth information
  • Monochrome: more sensitive to light
  • Wide angle: 150° (DFoV)
  • Easy to use: compatible with OAK FFC boards for evaluation
SKU: B0418 Categories: , ,
Product Description
OmniVision’s OV9282 is a 1MP (1280×800) global shutter grayscale image sensor. Arducam OV9282 camera module can be used in almost all OAK products (OAK-D, OAK-D S2 OAK-D Pro, OAK-D-PoE, OAK-D S2 PoE, etc.) as the stereo camera pair.
It is also compatible with OAK FFC boards (OAK-FFC-3P, OAK-FFC-4P), so you can easily evaluate its sensor and optics performance via a camera board and a flex cable.
Specification
SensorOV9282
Optical SizeType 1/4”
Pixel Size3μm×3μm
Shutter TypeGlobal Shutter
Max Sensor Resolution1280 x 800
Color Filter ArrayNone (Monochrome)
Resolution and Frame Rate
1280×800@60fps, 1280×720@60fps, 640×400@120fps
Supported Platform
Most OAK-D boards, OAK FFC boards (OAK-FFC-3P, OAK-FFC-4P)
Focus TypeFixed
Focus Distance50cm~INF
Lensf/2.0; EFL: 1.69mm; FoV: 150° (D)
IR Sensitivity
Built-in 650nm IR filter, sensitive to visible light only
Module Dimensions
8.5mm x 14.67mm
Documentations
Packing List
  • 1 x OV9282 Wide Angle Camera Module for DepthAI OAK
Weight0.05 kg
OAK
Edge AI
OV9282
Global Shutter
1MP
MONO
Global Shutter
Fixed Focus
