The Arducam 2.3MP AR0234 Global Shutter Color MIPI camera module is designed for DepthAI OAK,
Supported DeptAI version: BW1098FFC R0M0E0
The lens on this camera is not interchangeable, if you need to replace the lens, please contact sales in advance!Specification
- Sensor: Color global shutter AR0234
- Pixel Size: 3 μm x 3 μm
- Active array size: 1920x 1200
- Optical Size: 1/2.6 inch
- Focusing Range: 2m ~ infinite
- IR Sensitive: With IR filter
- Output interface: MIPI 2-Lane
- Output formats: RAW8/RAW10
- Maximum frame rate: 1920x 1200@60 fps
- Board Size: 38mm x 38mm
- Lens: Low distortion M12 lens (Part Number: M25360H06S)
- EFL: 3.6mm
- F.NO: 2.8
- HFOV: 90 Deg
- 1 pcs Arducam 2.3MP AR0234 Global shutter Color MIPI camera module 22pin for DepthAI OAK
- 1 pcs 150mm 22pin-26pin FPC cable
