The Arducam OG02B10 color global shutter supports embedded systems such as PC and Raspberry Pi well, and can also provide customized support TK/TX boards for Odroid, Beaglebone Black, and Nvidia JETSON.
Applications:
- Augmented and virtual reality
- Drones
- 3D imaging
- Machine vision
- Industrial bar code scanning
- Industrial automation
- Sensor: Color global shutter OG02B10
- Pixel Size: 3 μm x 3 μm
- Active array size: 1600H×1300V
- Optical Size: 1/2.9 inch
- Output formats: 8/10-bit BW RAW
- Frame Rate: 1600×1300@60fps; 1600×1080@80fps; 1280×720@120fps
- Lens: M12 lens mount, focal length of 2.8mm±5%, F/2.8±5%, 110 degrees horizontal field of view (HFoV)
- IR Sensitivity: Integral IR filter, visible light only
- Board Size: 40mm x 40mm
Documentation:
1.Introduction Arducam USB3 camera Shield board is the latest super high-speed USB camera expansion board, which provides improved performance and enhanced functions than the previous USB2.0 camera expansion board. It not only supports high resolution and high frame rate image sensors but also supports stereo camera and IRCUT control functions. Using a given camera profile, […]OG02B10 MIPI Camera with USB3.0 Camera Shield Plus
Video:
Package Including:
- 1 pcs Arducam OG02B10 1/2.9-inch Color M12 Camera Module
- 1 pcs Arducam USB3.0 Camera Shield Plus
- 1 pcs USB3 Cable
