[Discontinued] Arducam 2MP Global Shutter OG02B10 Color Camera Modules with M12 lens for Raspberry Pi
  • Note: This camera module is discontinued currently. Please check new version with SPI feature SKU: B0348
SKU: B0343 Category:
Arducam 2MP OG02B10 Global shutter camera module is mainly designed for Raspberry pi boards, and it can be connected directly to RPi’s CSI-2 camera interface without additional hardware. This camera is based on 1/2.9-inch Omnivision OG02B10 image sensor which adopts OmniPixel3-GS™ technology to provide full-frame, sub-sampled, and windowed 8/10-bit MIPI images, and capable of operating at up to 60fps in full resolution at 2-lane MIPI bus with complete user control over image quality.
Due to the sensor’s high resolution, the OG02B10 offers exceptionally accurate gaze- and eye-tracking capabilities, and it achieves high near-infrared quantum efficiency to minimize active illumination power and reduce the system power requirements.
Sensors
  • Sensor: Global Shutter OG02B10 Color
  • Pixel size: 3 µm x 3 µm
  • Active array size: 1600 x 1300
  • Optical Format size: 1/2.9″
  • Maximum image transfer rate: 1600 x 1300: 60 fps
  • Support for image sizes: 1600 x 1300, 1280 x 720, 640 x 480
  • Input clock frequency: 6~27 MHz
  • Max S/N ratio: 37.4 dB
  • Dynamic range: 68 dB
  • Lens Thread: M12 x 0.5P
  • Field of View(FoV): 83°(H)
  • IR Sensitivity: with IR Filter, sensitive to visible light
Camera Module
  • Output interface: 2-lane MIPI
  • Output formats: RAW 8/10 bit
  • Minimum exposure time: 1 row period (11.3us at the resolution of 1600×1300 on Raspberry Pi)
Applications:
  • Drones
  • 3D imaging
  • Machine vision
  • Industrial automation
  • 1pcs Arducam 2MP Global Shutter OG02B10 Color Camera Module for Raspberry Pi
  • 1pcs Arducam 80mm 22pin Ribbon FPC Cable
  • 1pcs Arducam 150mm 15pin to 22pin Ribbon FPC Cable
MIPI
IR sensitivity
IR sensitive
Bayer RGB
Global Shutter
