[Discontinued] Arducam 0.3MP MT9V111 1/4” 640*480 Camera
SKU: B0059 Category:
  • Onboard LDO regulators for 2.8V
  • Single 3.3V power input
  • 2.54mm (0.1 inch) standard pinout
  • SOC Camera Module
  • Active array size: 640 x 480
  • Optical Format 1/4 inch (4:3)
  • Fast Rate: 30fps VGA, 60fps CIF, 90fps QVGA at 27MHz Clock
  • Responsivity: 1.9V/lux-sec (550nm)
  • Dynamic Range: 60dB
  • ITU_R BT.656 (YCbCr), YUV, 565RGB, 555RGB, and 444RGB output data formats
  • External 1/4 inch high quality 6mm/F2.0 M12x0.5 mount
Package Including:
  • MT9V111 640*480 0.3 Mega pixels Camera Module Compatible w/ OV7670
Instruction Manual.pdf
usb_camera_shield_release_blog_thumbnail
ArduCAM USB Camera Shield Released
The ArduCAM USB camera shield is a universal camera control board designed for both PCs and embedded systems like the Raspberry Pi, TI Beaglebone, and similar products. It supports most parallel interface image sensors ranging from 0.3MP to 14MP, including both global and rolling shutter sensors. The camera is packaged with the software you need to put it to […]
You can purchase this item fromArducam distributors
