The Arducam Quick-Bootup 3MP DVP Camera is designed for IoT applications that demand speed and efficiency. With an impressive 300ms quick bootup, this camera allows for rapid image capture and immediate reaction times, making it ideal for dynamic environments. Its power-efficient design ensures that the camera switches off when idle, conserving energy and waking up in just 300ms when needed. Featuring a high-resolution 3MP image sensor, it delivers stunning image quality for various applications. Compatible with multiple MCUs, including RPi Pico, Arduino, Nordic, ESP, STM, and Renesas, this camera is versatile and easy to integrate. Its compact size and open-source SDK make it user-friendly, perfect for quick project evaluations. With a wide-angle lens for a larger view, the Arducam Quick-Bootup Camera is the ultimate solution for efficient and effective IoT vision applications.
- Wearable Devices
- Critical Assets Monitoring
- Wildlife Observation
- Environmental Observation
- Wild Fire Monitoring
- Disaster Response
- [NOTE] This item is currently available only for custom inquiries. Please reach out for pricing and more info.
- Instant On: Boots up in just 300ms, ensuring rapid image capture for applications that require immediate responsiveness in dynamic environments.
- Power Efficient: Automatically switches off when idle and can wake up in 300ms, significantly extending battery life and reducing power consumption for IoT applications.
- Compact Design: Its small form factor makes it easy to embed in devices, ideal for space-constrained applications while maintaining powerful performance.
- High Resolution: Equipped with a 3MP performance image sensor, it delivers high-quality images with excellent clarity, perfect for capturing critical details.
- Wide Compatibility: Supports a variety of MCUs with DVP interfaces, including RPi Pico, Arduino, Nordic, ESP, STM, and Renesas, allowing for easy integration into diverse projects.
- Open Source SDK: Comes with an open-source SDK, enabling developers to customize functionality, promoting flexibility for quick project evaluations and prototyping.
| Image Sensor | |
| Sensor | Mega DVP 3MP |
| Color Filter Array | Color |
| Shutter Type | Rolling Shutter |
| Optical Size | 1/4″ |
| Output Format | JPG/YUV/RGB |
| Pixel Size | 1.4μm |
| Max Resolution | 2048×1536 |
| Resolution&Frame Rate | 2048×1536@12fps |
| IR Sensitivity | Integrated IR Filter | Lens |
| Focus Type | Fixed Focus |
| FOV | 88°(D) |
| Lens Mount | Stock Lens |
| F.NO | 2.0±5% |
| E.F.L | 2.46mm |
| Default Focus Range | 0.42m-INF |
| Distortion | <-3.2% |
| Electrical and Mechanical | |
| Overall Size(LxWxH) | 12.92mm x 17.00mm x 5.32mm |
| Operating Temp. | -30°C to 70°C |
| Power Requirements | AVDD MAX:2.8V/63mA DOVDD MAX:2.8V/160mA |
- 1 x Arducam 3MP Mega DVP Camera Module
