The Arducam IMX477P camera module is a high-quality imaging solution designed for advanced applications. Featuring a 1/2.3″ 12.3MP IMX477P CMOS, this module offers superior image quality and high resolution, making it an excellent choice for projects requiring detailed and vibrant visuals.
The advanced imaging capabilities are further enhanced by an M12 lens with an 88° diagonal field of view (DFoV), ensuring that every shot is crisp and clear. One of the standout features of the Arducam IMX477P is its compact design. Measuring just 24x25mm, the mini camera board is highly versatile and can be seamlessly integrated into various projects.
Designed specifically for Rock 5A and 5B, the Arducam IMX477P camera module offers wide compatibility and seamless integration. Arducam has provided the necessary driver, requiring only a simple installation process to get started. This user-friendly setup makes it easy even for those with minimal technical expertise to install and use the camera efficiently. With its blend of high-quality imaging, compact design, and ease of use, the Arducam IMX477P is a top-tier choice for anyone looking to enhance their Rock-based projects.
- Wildlife Photograph
- Machine Learning
- Home Security System
- AI applications
- DSLR Camera Control
- High-Quality Camera: Featuring a 1/2.3″ 12.3MP IMX477P CMOS, this module delivers superior image quality with high resolution.
- Advanced Imaging: Equipped with an M12 lens offering a diagonal field of view (DFoV) of 88°, it ensures crisp and clear images.
- Compact Design: With a mini camera board size of 24x25mm, this module is easy to integrate into various projects, making it highly versatile.
- Wide Compatibility: Designed specifically for Rock 5A and 5B, the Arducam IMX477P camera module ensures seamless integration with these devices.
- Easy Setup: Requires only a simple driver installation, making it user-friendly and convenient.
| Image Sensor | |
| Image Sensor | IMX477P |
| Still Resolution | 12.3 MP |
| Color Filter Type | Color |
| Shutter Type | Rolling shutter |
| Optical Size | 1/2.3″ |
| Output Format | RGGB10 |
| Pixel Size | 1.55 µm x 1.55 µm |
| Sensor Active Area | 4056(H)×3040(V) |
| Sensor Frame Rate | 4056×3040@10fps, 3840×2160@20fps, 1920×1080@60fps | Lens |
| Lens Mount | M12 S-mount |
| Focus Type | Manual Focus |
| FOV | 88°(D)×75°(H)×60°(V) |
| F.NO | F2.8 |
| E.F.L | 3.9mm |
| Default Focus Range | 0.3m-∞ |
| IR Sensitivity | Integral IR-cut Filter, visible light only |
| Electrical and Mechanical | |
| Operating Voltage | 3.3V |
| Operating Temp. | 32°F-158°F (0°C to 70°C) |
| Power Requirements | Max: 300mA |
| Camera Board Size | 25 × 24mm |
| Functionality and Compatibility | |
| Supported OS | ROCK 5A: Build 18 ROCK 5B: Build 39 |
| Supported Platform | Rock 5A, 5B |
- 1× IMX477P Camera Module for Rockpi
- 1× 15cm 0.3mm 31Pin-0.5mm 22Pin FPC
- The product does not come with any Rockpi motherboards included.
- This Camera Module requires configuration in advance on a Rockpi. For detailed instructions, kindly consult the Quick Start Guide provided below.
