Arducam 5MP OV5647 Miniature Camera Module with Long Flex Cable for Raspberry Pi 4/3B+/3 (NoIR)
Arducam 5MP OV5647 Camera Module with Motorized IR Cut Filter M12 LS1820 Lens for Raspberry Pi 5/4/3B+/3 (NoIR)
B0151
  • High-Definition video camera for Raspberry Pi Model A or B, B+, Pi2B, Pi3B, Pi5.
  • Replaceable Lens: Various M12 Lens for differnt requirement
  • Connection by a flat ribbon cable to 15-pin MIPI Camera Serial Interface (CSI) connector S5 on Raspberry Pi computer board
  • Motorized IR-CUT Switch: Onboard Motorized IR cut filter, support both visible and night vision
$34.99
This camera is developed for the application of the night vision. The Arducam OV5647 day and night camera can satisfied your requirement under different light conditions. The special struction is capable to achieve automatic IR-cut switching all-day. Attached with a M12x0.5 Mount LS1820 Lens that compatable with Raspberry Pi.
  • Home security
  • Robot cameras
  • Wildlife cameras
  • Cellular phones,PDAs,Toys
  • Digital still cameras,etc.
Sensor size 1/4” (OV5647)
Resolution 5MP 2592×1944
IR Sensitivity Motorized IR cut filter
Focus Type Manual
Lens Type M12 Lens
Dimension 36mm x 36mm
Peak Current 300mA
    Raspberry Pi 5
    • 1 x OV5647 NoIR Camera Board /w Motorized IR Cut Filter M12x0.5 Mount Lens LS1820 for Raspberry Pi
    • 1 x 15cm 15-15pin FPC cable
    • 1 x 15cm 15-22pin FPC cable
    5MP OV5647 Motorized IR-CUT Camera Modules
    Introduction Arducam 5MP OV5647 Motorized IR-CUT Camera Modules are designed for both daylight and night vision photography. The motorized IR cut filter can be switched ON/OFF automatically, and the infrared LEDs are automatically ON/OFF according to the light environment. The cameras in this serial are fully supported by all the Raspberry Pi board versions including […]
    noir_rpi_camera_blog_thumbnail
    ArduCAM NOIR Raspberry Pi camera with Motorized IR Cut Filter
    Background Raspberry pi camera has both color version pi camera board and NoIR version pi camera board. So let’s take a look at the difference between these two types of cameras. The color version pi camera has 650nm IR cut filter on top of the sensor, so it can only sensitive to visible light like […]
