12MP IMX708 Autofocus Wide Angle Camera Module 3 for Raspberry Pi, HDR Mode and PDAF supported
3MP ISX031 8-Channel GMSL2 Camera Kit for NVIDIA Jetson AGX Orin – 120 dB HDR, Built-in ISP, LED Flicker Mitigation, IP67 Waterproof, up to 15 m Cable Extension
Arducam IMX577 Mini Camera Module for Qualcomm RB3G2 and RUBIK PI 3
B0488
[12.3MP High Resolution] Capture detailed, sharp images with the Sony IMX577 sensor.
[Wide-Angle Lens] Fixed lens with low distortion for broad scene coverage.
[Mini Size] Compact design for easy integration and deployment.
[Flexible Interface] Works with both 2-lane and 4-lane MIPI data transfer.
[Dedicated for Qualcomm] Compatible with Qualcomm IQ8-EVK, IQ9-EVK, RB3G2, RB5G2, and RUBIK PI 3 platforms.
The Arducam 12.3MP IMX577 Mini Camera Module is a high-resolution imaging solution designed specifically for Qualcomm robotics platforms, including IQ8-EVK, RB3G2, and RUBIK PI 3, etc. Built around the Sony IMX577 sensor, it delivers up to 12.3MP of sharp, detailed images with a low-distortion wide-angle lens for natural scene capture. Its compact mini form factor makes it ideal for space-constrained designs such as drones, robots, and embedded vision systems. With support for both 2-lane and 4-lane MIPI CSI data transfer, the module offers flexibility to balance bandwidth needs and system performance, ensuring smooth integration into advanced AI and computer vision applications.
Robotics & Drones
Industrial Automation
AI & Computer Vision Projects
Smart Devices & Embedded Systems
Research & Prototyping
Surveillance & Monitoring
[12.3MP High-Resolution Sensor] – Built around Sony’s IMX577, this camera delivers crisp, detailed images that meet the demands of high-accuracy computer vision and AI applications.
[Low-Distortion Wide-Angle Lens] – Offers a broad diagonal field of view with minimal distortion, ensuring natural-looking images without edge warping.
[Compact Mini Module] – The small footprint makes it easy to deploy in space-constrained devices such as robots, drones, and embedded prototypes.
[Dedicated for Qualcomm]– Fully validated for Qualcomm IQ8-EVK, IQ9-EVK, RB3G2, RB5G2, and RUBIK PI 3 Platforms, offering seamless integration and stable performance on Qualcomm robotics systems.
[2Lane/4-Lane MIPI Support] – Provides flexibility in system design, with 2-lane mode for standard use and 4-lane mode available when higher bandwidth is required.
IMX577
Max Still Resolution
12.3 Megapixels
Color Filter Type
Color
Rolling
Optical Size
1/2.3″
Output Format
RAW
Pixel Size
1.55 µm x 1.55 µm
Sensor Active Area
4056(H) x 3040(V)
Resolution&Frame Rate
4056x3040@15fps, 1920x1080@30fps;
Focus Type
Fixed Focus
FOV
88°(D)×75°(H)×47°(V)
Lens Mount
M12
F.NO
F2.8
E.F.L
3.9mm
IR Sensitivity
Integral 650nm IR Filter
Default Focus Range
3M-INF
Weight
5g
Operating Voltage
3.3V
Power Consumption
Max: 300mA
Camera Board Size
24mm x 25mm
Overall Weight (Net)
10g
Camera Interface
MIPI CSI-2
Data Transmission Lanes
2-Lane/4-Lane
Supported Platforms
Qualcomm IQ8-EVK, IQ9-EVK, RB3G2, RB5G2, RUBIK PI 3
