The external trigger mode is to accepts the external input signal to trigger the image output. It can output an image when the rising edge of the external trigger signal coming. Therefore, it is suitable for capturing high-speed moving objects. In addition, the sensor enables the sleep state will greatly reduce the power consumption.
USB Global Shutter Cameras , UVC USB Camera Module
Arducam 2MP Global Shutter USB Camera Board for Computer, 50fps OV2311 Monochrome UVC Webcam Module with Low Distortion M12 Lens Without Microphones, Compatible with Windows, Linux, Android and Mac OS
Buy Now- Based on 2MP monochrome (black&white) global shutter sensor OV2311, assembled with a 75°(H) low distortion M12 lens without IR pass filter, sensitive to IR.
- Global Shutter: Shoot high-speed moving objects in crisp sharp images. Avoid the …
1. How to use UVC Camera on Windows
1.1 Supported resolutions and frame rates
MJPG | 1600×1200 50fps, 30fps, 15fps, 10fps |
MJPG | 1280×960 50fps, 30fps, 15fps, 10fps, 5fps |
MJPG | 1280×720 50fps, 30fps, 15fps, 10fps, 5fps |
MJPG | 800×600 50fps, 30fps, 15fps, 10fps, 5fps |
MJPG | 640×480 50fps, 30fps, 15fps, 10fps, 5fps |
MJPG | 320×240 50fps, 30fps, 15fps, 10fps, 5fps |
MJPG | 160×120 50fps, 30fps, 15fps, 10fps, 5fps |
YUV2 | 1600×1200 5fps |
YUV2 | 1280×720 5fps |
YUV2 | 800×600 5fps |
1.2 Maximum frame rate of The external trigger snapshot mode
Enable manual exposure and set the shortest exposure time,
In the case of MJPG 50fps, the external trigger frame rate can reach up to 45fps;
In the case of YUV2 5fps, the external trigger frame rate can reach up to 5fps.
1.3 External trigger function instructions
Step 1 Hardware
First of all, you need to solder the F and G pins. F is connected to the external trigger signal, and G is connected to GND.
It is required that the trigger signal pulse width tFSIN_High is not less than 2us, and the frequency cannot exceed the highest external trigger frame rate supported by the current frame rate.
Step 2 Enable the external trigger snapshot mode
The options menu can be used to select the preview and image parameters supported by this camera.
The low-brightness compensation option is enabled to enter the external trigger mode, and when it is disabled, the external trigger mode is exited.
1.4 Adjust exposure Manually
There is a switch behind the Exposure slider in the Camera Control. Select it to start manual exposure mode.
1.5 The Strobe signal
When the image is output, a flash signal output from S can drive flash to enhance exposure. The stroboscopic signal of the sensor can set the light point or time parameter. However, it can only output a fixed strobe signal because of a fixed UVC Camera configuration.
You need to solder the S and G pins when using the Strobe signal. S outputs the strobe signal and G connects to GND.
The output voltage of the Strobe signal of OV2311UVC is 3.3V, and the effective level is high. The width of the Strobe signal corresponding to different frame rates is as follows:
50fps | 3.50ms |
30fps | 5.42ms |
15fps | 11.22ms |
10fps | 16.05ms |
2. How to use UVC Camera on Linux
2.1. How to access UVC Camera using Command Line
2.1.1 Install V4L utils packages
sudo apt-get update sudo apt-get install v4l-utils
2.1.2 List all V4L device
v4l2-ctl --list-devices
2.1.3 List all resolutions and frame rates of different formats
v4l2-ctl --list-formats-ext -d 0
2.1.4 List all controls and their values
v4l2-ctl -l
2.1.5 How to use the control function
- Disable auto exposure
v4l2-ctl -c exposure_auto=1
- Set up exposure
v4l2-ctl -c exposure_absolute=500
- Enable the external trigger snapshot mode
v4l2-ctl -c exposure_auto_priority=1
