  3. USB cameras
  4. USB Camera Shield
  5. USB3.0 Camera Shield
Arducam USB3 camera shield is the latest super-speed USB camera shields, it offers the improved performance and enhanced functions than the previous USB2.0 camera shield. It not only supports high resolution and high frame rate image sensors, but also supports stereoscopy camera and IRCUT control feature. With the given camera configuration files, user can switch between different cameras without any effort. It is the ideal solution for camera evaluation/testing, robot/drone, IoT, machine vision and scientific applications.Now it well supports both PC and embedded system like Raspberry Pi, and also can provide customized support for Odroid, Beaglebone Black, Nvidia JETSON TK/TX boards. Please also note that when this USB3 camera used on USB2 port the performance will be greatly degraded.
  • Support any parallel image sensors (need proper register settings)
  • Support 8/10/12/14/16 bit pixel color depth
  • Support Stereoscopy mode for dual camera system
  • Build-in IRCUT control  (optional)
  • Need extra MIPI to parallel adapter board for supporting MIPI interface sensors (see Table1)
  • Support x86 PC, ARM 32/64bit, Odriod C2, Raspberry Pi hardware platforms
  • Support Windows, Linux OS, ROS
  • Support C/C++, Python Programming Languages
  • Provide free binary SDK library and demo software source code
  • Bandwidth: 5-Gbps USB3.0 PHY
  • Camera Databus: 16bit@100MHz
  • I/O Voltage Standard: 3.3V
  • Connector: Micro-USB3.0
  • Size: 40 x 40 mm
  • Weight: 10g
  • Power Consumption: 5V/300mA
Table 1 Featured Parallel Camera Modules Supported
ResolutionFrame RateCamera ModuleSensor Vendor
0.3MP60fpsMT9V022/MT9V034Aptina
1.3MP50fpsAR0134/AR0135Aptina
9MP7fpsMT9N001Aptina
10MP6fpsMT9J001/MT9J003Aptina
14MP5fpsMT9F001/MT9F002Aptina
Table 2 Featured MIPI Camera Modules Supported (Need MIPI-Parallel Adapter board)
0.3MP240fpsSC031GS(MIPI)SmartSense
0.3MP100fpsOV7251 (MIPI)Omnivision
5MP15fpsOV5647 (MIPI)Omnivision
8MP8fpsIMX219(MIPI)Sony
13MP5fpsOV13850 (MIPI)Omnivision
Table 3 Featured HISPI Camera Modules Supported (Need HISPI-Parallel Adapter board)
14MP6fpsMT9F002(HISPI)ONsemi
18MP3fpsAR1820HS(HISPI)ONsemi
Arducam USB3 Camera Shield DataSheet
Arducam USB3 Camera Shield User Guide
How can we help?
