Cameras for Raspberry Pi
  3. Cameras for Raspberry Pi
  4. Synchronized Stereo Camera HAT
  5. Driver Installation For Arducam 1MP OV9281 Synchronized Camera
Driver Installation(Previous Version)
1. Driver note
Note:
This driver can just be installed on the Buster system.
  • Official driver
  • Arducam MIPI camera driver
  • Arducam V4L2 driver
1)Arducam MIPI camera driver is not in conflict with the official driver.
2)Arducam V4L2 driver is in conflict with the official driver. If you want to use the official driver, you need to uninstall the Arducam V4L2 driver first.
3)Arducam V4L2 driver is in conflict with Arducam MIPI camera driver. If you want to use the Arducam MIPI camera driver, you need to uninstall the Arducam V4L2 driver first.
4)Arducam V4L2 driver automatically overwrites the other two drivers. After uninstalling the Arducam V4L2 driver, it automatically reverts to the official driver.
2. Check the driver
Determine if the system is installed with the Arducam V4L2 driver.
Enter the config.txt :
sudo nano /boot/config.txt
Press【PageDown】several times or scroll your mouse wheel down to check if there is “dtoverlay=arducam”.
dtoverlayarducam”
1)If you see “dtoverlay=arducam”, the Arducam V4L2 driver has been previously installed and is in a valid state. Press 【Ctrl+X】, 【Enter】to exit the config.txt.
2)If you see “#dtoverlay=arducam”, it means you have installed Arducam V4L2 driver before, but it is uninstalled now, remove the “#” to restore the V4L2 driver. Then reboot Pi to take effect. Press 【Ctrl+X】【Y】,【Enter】to save the change and exit the config.txt.
3)If you don’t see “dtoverlay=arducam” or “#dtoverlay=arducam”, it means that Arducam’s V4L2 driver has never been installed before, so you need to follow the instructions below for a complete installation. Press 【Ctrl+X】, 【Enter】to exit the config.txt.
3. Install the driver
#Download driver package
wget https://github.com/ArduCAM/Arducam_OBISP_MIPI_Camera_Module/releases/download/v2.0/arducam_obisp_camera_driver.tar.gz
Download driver package1 1
#Extract the archive files
tar zxvf arducam_obisp_camera_driver.tar.gz
Extract the archive files1 3
#Enter the extracted folder
cd arducam_obisp_camera_driver
#Install the driver
./install.sh
Install the driver1 2
#Reboot the device
Press y, and then hit Enter to reboot.
Get an error?
If your operating system is not released by the official Raspberry Pi, the driver installation will report an error and give a version error message.
version error b0267
Check out Raspberry Pi official supported operating system:
https://www.raspberrypi.org/software/operating-systems/
4. Uninstall the driver
Note that the driver will occupy CSI hardware resources. After installation, you will not be able to use the raspistill tool. There are two ways to uninstall Arducam V4L2 driver:
cd Release/
./uninstall_driver.sh
NOTE
You have to reboot your Pi to make it effective.
Method 2: Modify configuration files
1)Type the following command:
2.Press【PageDown】several times or scroll your mouse wheel down to check if there is “dtoverlay=arducam”.
dtoverlayarducam”
Modify “dtoverlay=arducam” as “#dtoverlay=arducam” to uninstall the V4L2 driver. Press 【Ctrl+X】【Y】,【Enter】to save the change and exit.
NOTE
First Use
1. Check whether the camera is detected
ls /dev/video0
Check whether the camera is detected b0267
2. Check the video format supported
v4l2-ctl --list-formats-ext
Check the video format supported b0267 pi
Run the command without results?
You might have to check the ribbon connection or install the drivers correctly, then reboot the Raspberry Pi.
3. Preview the camera feed in real-time
#RAW10
arducamstill -t 0 -pixfmt Y10P -w 5120 -h 800
#RAW8
arducamstill -t 0 -pixfmt GREY -w 5120 -h 800
Preview the camera feed in real time b0267 pi 1
The last line shows frame in real time.
​GREY for RAW8 and Y10P for RAW10.
​-w and -h indicate the width and height of the input image.
pic b0267
Press Ctrl+C to exit the preview.
NOTE
The HAT can output 45fps, but the Raspberry Pi performance is limited to displaying 30fps (the 8G version of the Raspberry Pi can output 38fps).
Advanced Commands
#View v4l2 command parameters
v4l2-ctl -l
#Adjust exposure
v4l2-ctl -c exposure=100
#Adjust gain
v4l2-ctl -c gain=14
4. Receive data without displaying the image
#RAW10
v4l2-ctl --set-fmt-video=width=5120,height=800,pixelformat='Y10P' --stream-mmap --stream-count=-1 -d /dev/video0
#RAW8
v4l2-ctl --set-fmt-video=width=5120,height=800,pixelformat='GREY' --stream-mmap --stream-count=-1 -d /dev/video0
frame rate when displaying the image
Receive data without displaying the image b0267 pi
frame rate when receiving data without displaying the image
5. Adjust exposure
#Adjust exposure:
v4l2-ctl -c exposure=1000
v4l2-ctl -l
v4l2-ctl -c exposure=4000
Adjust exposure b0267 pi
Adjust exposure b0267 pi 1
6. Adjust gain
#Adjust gain:
v4l2-ctl -c gain=12
v4l2-ctl -l
v4l2-ctl -c gain=12
Adjust gain b0267 pi
Adjust gain b0267 pi 1
7. Change frame rate
Type the following command, and change the value of “X” to change the frame rate.
v4l2-ctl -c frame_rate=X
For example, you want to change the frame rate to 30. First, open two terminals, type the following command in the first terminal
Change frame rate b0267
The last line shows the current frame rate in real-time, and the RAW8 configuration defaults to 58fps.
Type the following command in the second terminal to change the frame rate:
v4l2-ctl -c frame_rate=30
Change frame rate b0267 1
The frame rate changes to 30fps.
v4l2-ctl -l
Change frame rate b0267 2
You can change the frame rate from 5fps to 46fps. If the set frame rate exceeds the maximum value, it will work according to the maximum value. The same goes for the minimum value.
Important Note
For example, if the frame rate is set to 46 fps, the display only goes up to 38fps.
IMPORTANT NOTE b0267 pi1
But when you use only receiving data without displaying the image, the frame rate goes back to 45fps. (The frame rate values here are not real-time and are calculated iteratively with historical values, changing slowly.)
IMPORTANT NOTE b0267 pi2
