This Arducam quadrascopic camera bundle incorporates four 1MP OV9281 global shutter cameras, and the cutting-edge MIPI stereo camera breakthrough from Arducam – The Arducam Camarray HAT. As the upgraded version of Arducam Synched Stereo Camera HAT, the Camarray further pushes the multi-camera limits and doubles the interfacing capabilities to allow 4 synchronized MIPI camera modules to be interfaced to a single MIPI CSI-2 slot on prevailing single-board computers like Raspberry Pi, Jetson Nano, and Jetson Xavier NX.
Also, as the Camarray HAT releases, Arducam starts to support a variable baseline for stereo camera applications with some modified Arducam camera modules, such as those OV9281 ones included in this bundle. Since no shared camera board or clock-sharing soldering is required for the image sensors, you can kick off your prototyping for stereo camera applications and then decide the optimal baseline. Arducam also accepts subsequent customizations for your stereo camera applications.
What is Camarray
NOTE
Common Specs
Sensor Model | OV9281 |
Active Pixels | 1280*4×800 |
Resolution | 1MP*4 |
Pixel Size | 3μm×3μm |
Lens Assembly
Interchangeability | YES |
F/NO | 2.8 |
Focus Type | Manual Focus |
Lens Mount | M12 Lens |
Board
HAT Size | 65×56 mm |
Camera Board Size | 40×40 mm |
OV9281 Camera Board Mechanical Drawing
4 | GND | Ground | Ground |
8 | GND | Ground | Ground |
Connector & Cable
Ribbon Cable Length | 150mm (22-pin), 300mm(15-22pin), 73mm(15-22pin) |
Pin # | Name | Description |
1 | GND | Ground |
4 | GND | Ground |
7 | GND | Ground |
10 | GND | Ground |
11 | CAM_IO0 | Power Enable |
12 | CAM_IO1 | LED Indicator |
13 | CAM_SCL | I2C SCL |
14 | CAM_SDA | I2C SDA |
15 | CAM_3V3 | 3.3V Power Input |
Frame Rates | [email protected]*4 × 800(on RPi) [email protected]*4 × 800(on Jetson) |
Quick Start Guide
The driver only supports the following kernel version:
- 4.19.113-v7+
- 4.19.118
- 4.19.118-v7+
- 4.19.118-v7l+
- 5.4.42-v7+
- 5.4.51+
- 5.4.51-v7+
- 5.4.51-v7l+
Hardware Setup
Driver Installation
1. Driver note
- Official driver
- Arducam MIPI camera driver
- Arducam V4L2 driver
1)Arducam MIPI camera driver is not in conflict with the official driver.
2)Arducam V4L2 driver is in conflict with the official driver. If you want to use the official driver, you need to uninstall the Arducam V4L2 driver first.
3)Arducam V4L2 driver is in conflict with Arducam MIPI camera driver. If you want to use the Arducam MIPI camera driver, you need to uninstall the Arducam V4L2 driver first.
4)Arducam V4L2 driver automatically overwrites the other two drivers. After uninstalling the Arducam V4L2 driver, it automatically reverts to the official driver.
2. Check the driver
Determine if the system is installed with the Arducam V4L2 driver.
Enter the config.txt :
sudo nano /boot/config.txt
Press【PageDown】several times or scroll your mouse wheel down to check if there is “dtoverlay=arducam”.
1)If you see “dtoverlay=arducam”, the Arducam V4L2 driver has been previously installed and is in a valid state. Press 【Ctrl+X】, 【Enter】to exit the config.txt.
2)If you see “#dtoverlay=arducam”, it means you have installed Arducam V4L2 driver before, but it is uninstalled now, remove the “#” to restore the V4L2 driver. Then reboot Pi to take effect. Press 【Ctrl+X】, 【Y】,【Enter】to save the change and exit the config.txt..
3)If you don’t see “dtoverlay=arducam” or “#dtoverlay=arducam”, it means that Arducam’s V4L2 driver has never been installed before, so you need to follow the instructions below for a complete installation. Press 【Ctrl+X】, 【Enter】to exit the config.txt.
3. Install the driver
#Download driver package
#Extract the archive files
tar zxvf Release.tar.gz
#Enter the extracted folder
cd Release/
#Install the driver
./install_driver.sh
#Reboot the device
Press y
, and then hit Enter
to reboot.
Get an error?
If your operating system is not released by official Raspberry Pi, the driver installation will report an error and give a version error message.
Check out Raspberry Pi official supported operating system:
4. Uninstall the driver
Note that the driver will occupy CSI hardware resources. After installation, you will not be able to use the raspistill tool. There are two ways to uninstall Arducam V4L2 driver:
cd Release/
./uninstall_driver.sh
NOTE
You have to reboot your Pi to make it effect.
Method 2: Modify configuration files
1)Type the following command:
2.Press【PageDown】several times or scroll your mouse wheel down to check if there is “dtoverlay=arducam”.
Modify “dtoverlay=arducam” as “#dtoverlay=arducam” to uninstall the V4L2 driver. Press 【Ctrl+X】, 【Y】,【Enter】to save the change and exit.
NOTE
First Use
1.Check whether the camera is detected
ls /dev/video0
2.Check the video format supported
v4l2-ctl --list-formats-ext
Run the command without results?
You might have to check the ribbon connection or install the drivers correctly, then reboot the Raspberry Pi.
3.Preview the camera feed in real time
#RAW10
arducamstill -t 0 -pixfmt Y10P -w 5120 -h 800
#RAW8
arducamstill -t 0 -pixfmt GREY -w 5120 -h 800
The last line shows frame in real time.
GREY for RAW8 and Y10P for RAW10.
-w and -h indicate the width and height of the input image.
Press Ctrl+C to exit the preview.
NOTE
The HAT can output 45fps, but the Raspberry Pi performance is limited to displaying 30fps (the 8G version of the Raspberry Pi can output 38fps).
Advanced Commands
#View v4l2 command parameters
v4l2-ctl -l
#Adjust exposure
v4l2-ctl -c exposure=100
#Adjust gain
v4l2-ctl -c gain=14
4.Receive data without displaying the image
#RAW10
v4l2-ctl --set-fmt-video=width=5120,height=800,pixelformat='Y10P' --stream-mmap --stream-count=-1 -d /dev/video0
#RAW8
v4l2-ctl --set-fmt-video=width=5120,height=800,pixelformat='GREY' --stream-mmap --stream-count=-1 -d /dev/video0
5.Adjust exposure
#Adjust exposure:
v4l2-ctl -c exposure=1000
v4l2-ctl -l
v4l2-ctl -c exposure=4000
6. Adjust gain
#Adjust gain:
v4l2-ctl -c gain=12
v4l2-ctl -l
v4l2-ctl -c gain=12
7.Change frame rate
v4l2-ctl -c frame_rate=X
For example, you want to change the frame rate to 30. First, open two terminals, type the following command in the first terminal
v4l2-ctl -c frame_rate=30
v4l2-ctl -l
IMPORTANT NOTE
For example, if the frame rate is set to 46 fps, the display only goes up to 38fps.
But when you use only receiving data without displaying the image, the frame rate goes back to 45fps. (The frame rate values here are not real-time and are calculated iteratively with historical values, changing slowly.)
Display Images via VLC Media Player
The Raspberry Pi system comes with a VLC madia player.
1.Open VLC media plyer
2.Select 【Media】→【Open Capture Device…】
3.【Video device name】→ select “/dev/video0“→ click 【Play】
It may be stuck due to Raspberry Pi performance and VLC media player.
4.Adjust the exposure, gain, and frame rate
【Tool】→【Effects and Filters】
Drag the different slider to adjust the corresponding parameter.
Display Images via Mplayer
1.Install mplayer
sudo apt-get install mplayer
2.Display images
The image screen may be too large for the display to be complete. You need to drag the title bar to move the window to see the full image. (The image is pretty smooth.)
mplayer tv:// -tv driver=v4l2:device=/dev/video0 -zoom -x 1280 -y 200
What’s Next
Application Note
Use with Arducam USB3.0 32b Camera Shield
column | raw | FPS | bandwidths/MB |
5120 | 800 | 45.0 | 175.8 |
Please strictly follow the installation and operation order below, otherwise errors will occur!
1.Download File here.
2.Connect the camera module to the HAT then connect HAT to the USB Camera Shield in the case of a total power failure.
3.Power the HAT through micro USB port,then power the USB Camera Shield.
4.Run USBTest
5.Scan and select the camera device number
5.Select CfgFile
6.Click 【load】- Click【open】
7.Power down the HAT then power the HAT.
8.Click【play】
